Thingworx server not connecting
AP_9587236
My thingworx instance was working fine. Suddenly now it shows
"Errors
503 Service Unavailable
Back to Composer".
What to do now?
This error not occuring after installation. Thingworx was working fine for years, suddenly this error happened. Thanks for your help.
I cleared this error "12:13:21.173 [main] ERROR com.thingworx.system.configuration.PlatformSettings - Configuration setting ContentTypeSettings.supportedMediaEntityContentTypes cannot be null" in logs. Its working now.
So i added this code in platform-settings.json.
"ContentTypeSettings": {
"supportedMediaEntityContentTypes":["image/svg+xml","image/png","image/gif","image/bmp","image/jpeg","application/pdf", "application/json", "image/vnd.microsoft.icon"]
6 REPLIES 6
cmorfin
(To:AP_9587236)
Hi @AP_9587236
You can check the Tomcat and ThingWorx log files to check for errors and possibly restart Tomcat
Hope this helps
Regards
Christophe
Sorry this is not a accepted solution. By mistake i clicked the button.
Btw @cmorfin , i tried restarting tomcat, cleared logs, updated chrome, restarted system, checked platform-setting file, cleared storage space in machine, no other apps are  running. But still thingworx server is not connecting but tomcat is working fine.
I seen error in twdata of pgAdmin. I attached the image. Does that matters?
And I can see these errors in Application logs:-
2021-08-24 15:40:30.229+0530 [L: ERROR] [O: c.t.s.ThingWorxServer] [I: ] [U: SuperUser] [S: ] [T: main] [message: Connections could not be acquired from the underlying database!]
2021-08-24 15:40:30.255+0530 [L: ERROR] [O: c.t.s.ThingWorxBootstrapper] [I: ] [U: SuperUser] [S: ] [T: main] [message: Unable to initialize and start system: Connections could not be acquired from the underlying database!]
2021-08-24 15:40:30.255+0530 [L: ERROR] [O: c.t.s.ThingWorxBootstrapper] [I: ] [U: SuperUser] [S: ] [T: main] *** CRITICAL ERROR ON STARTUP: Unable to initialize and start system: Connections could not be acquired from the underlying database!
2021-08-24 15:40:30.255+0530 [L: ERROR] [O: c.t.s.ThingWorxBootstrapper] [I: ] [U: SuperUser] [S: ] [T: main] *** Web Application STATE is being set to ERROR! ***
cmorfin
(To:AP_9587236)
Hi @AP_9587236
Can you upload tomcat and ThingWorx log files ?
regards
Christophe
I attached tomcat logs here. And thingworx logs file exceeds limit. Kindly download from this link.
https://drive.google.com/file/d/1srnivIufO8ukjnDH77MQWL5ACrkvYHv8/view?usp=sharing
cmorfin
(To:AP_9587236)
@AP_9587236
I see from your other post that you identify the root cause, basically ThingWorx cannot connect to Postgres.
The article https://www.ptc.com/en/support/article/CS235937 should help you isolate what is wrong.
regards
Christophe
