Thingworx8.1 installation error with tomcat
snam1
2-Explorer
I'm trying to install TWX8.1 accoring to manual
The tomcat service dosen't work.
when I am in the step of '$ sudo systemctl enable tomcat.service', it has an error message : 'badmessage'
'tomcat.service' has
  [Unit]
  Description=Apache Tomcat Web Application Container
  After=network.target
  [Service]
  Type=forking
  PIDFile=/var/run/tomcat.pid
  Environment=CATALINA_PID=/var/run/tomcat.pid
  Environment=JAVA_HOME=/usr/lib/jvm/jdk1.8.0_131
  Environment=CATALINA_HOME=/usr/share/tomcat8.5/8.5.13
  Environment=CATALINA_BASE=/usr/share/tomcat8.5/8.5.13
  Environment=CATALINA_OPTS=
  ExecStart=/usr/share/tomcat8.5/8.5.13/bin/jsvc \
                              -Dcatalina.home=${CATALINA_HOME} \
                              -Dcatalina.base=${CATALINA_BASE} \
                              -Djava.awt.headless=true -
Djava.net.preferIPv4Stack=true -Dserver -Dd64 -XX:+UseNUMA \
                              -XX:+UseConcMarkSweepGC -Dfile.encoding=UTF-8 \
Djava.library.path=${CATALINA_BASE}/webapps/Thingworx/WEB-INF/extensions \
                              -cp ${CATALINA_HOME}/bin/commons-
daemon.jar:${CATALINA_HOME}/bin/bootstrap.jar:${CATALINA_HOME}/bin/tomcat-
juli.jar \
                              -user tomcat8.5 \
                              -java-home ${JAVA_HOME} \
                              -pidfile /var/run/tomcat.pid \
                              -errfile ${CATALINA_HOME}/logs/catalina.out \
                              -outfile ${CATALINA_HOME}/logs/catalina.out \
                              $CATALINA_OPTS \
                              org.apache.catalina.startup.Bootstrap
  [Install]
  WantedBy=multi-user.target
and status of tomcat get a message with "Trailing garbage, ignoring." in line
'ExecStart=/usr/share/tomcat8.5/8.5.13/bin/jsvc \'
dhwang
(To:snam1)
I had similar issue under CentOS
Even through failed "sudo systemctl enable tomcat.service" tomcat has been started without error as "sudo systemctl start tomcat" command
Did you get any issue during "jsvc" step such as tar/make etc.. ?
Dane
dhwang
(To:dhwang)
Here is suggestion..
1. Stop all process for tomcat
2. Grant all permission to tomcat installation directory - sudo chmod -R 777 .....
3. Start tomcat as "startup.sh" as root
4. Access to UI
If failed please share "catalina.out"
Dane
Dane
Based on the error message "Trailing garbage, ignoring" looks you have some character after "\". Can you share 'tomcat.service' file?
--Marek
