ThingworxMultiEventSubscription with Java using ExtensionSDK
atondorf
Hello everybody,
has anyone exprience or can help to create a MultiEventSubscription using the ExtensionSDK?
So I am currently using Thingworx 9.6.1 with the ExtensionSDK 9.6.0. The latest available Eclipse Plugin i found is 9.0.1. When I use this combination to create an Extension and a ThingShape with an event and a subscription i get this result:
@ThingworxEventDefinitions(events = {
@ThingworxEventDefinition(name = "Message", description = "", category = "Message", dataShape = "TWX.Core.Message_DS", isInvocable = true, isPropertyEvent = false, isLocalOnly = false, aspects = {}) })
@ThingworxSubscriptions(subscriptions = {
@ThingworxSubscription(source = "", eventName = "Message", sourceProperty = "", handler = "OnMessage", enabled = true) })
public class ActorTS {
	private static Logger _logger = LogUtilities.getInstance().getApplicationLogger(ActorTS.class);
	public ActorTS() {
		// TODO Auto-generated constructor stub
	@ThingworxServiceDefinition(name = "OnMessage", description = "Subscription handler", category = "", isAllowOverride = false, aspects = {"isAsync:false" })
	public void OnMessage(
		@ThingworxServiceParameter(name = "eventData", description = "", baseType = "INFOTABLE") InfoTable eventData,
		@ThingworxServiceParameter(name = "eventName", description = "", baseType = "STRING") String eventName,
		@ThingworxServiceParameter(name = "eventTime", description = "", baseType = "DATETIME") DateTime eventTime,
		@ThingworxServiceParameter(name = "source", description = "", baseType = "STRING") String source,
		@ThingworxServiceParameter(name = "sourceProperty", description = "", baseType = "STRING") String sourceProperty) {
But I deeper look into the ExtensionSDK.shows, that there are special annotations for @ThingworxMultiEventSubscription:
@Target({ElementType.ANNOTATION_TYPE})
@Retention(RetentionPolicy.RUNTIME)
@ThingworxExtensionApiAnnotation(since = {9, 5, 1})
public @interface ThingworxMultiEventSubscription {
  String name() default "";
  String description() default "";
  boolean enabled() default false;
  String handler();
  String[] aspects() default {};
  ThingworxSubscriptionEvent[] events() default {};
But there is no function in Eclipse to use them, no documentation and no example.
Please help!
atondorf
(To:Constantine)
Hi Constantin,
that was the right hint ... especially the @ThingworxSubscriptionEvent-Annotation. But some more steps to go:
- I wanted the Subscription to be stateful and sequentially => aspects = { "isStateful:true" }
- I don't wanted to show up the Subscription Handler as a Separate Service => isPrivate = true
- The parameters of the Subscription Handler are different as it is a "MultiEventSubscription" ...
  @ThingworxEventDefinition(name = "Message", description = "", category = "AMQP", dataShape = "TWX.Core.Message_DS", isInvocable = true, isPropertyEvent = false, isLocalOnly = true, aspects = {}),
@ThingworxMultiEventSubscriptions(subscriptions = {
  @ThingworxMultiEventSubscription(name = "SubMessageNew", enabled = true, handler = "OnMessageNew", aspects = { "isStateful:true" }, events = {
    @ThingworxSubscriptionEvent(source = "", eventName = "Message",   sourceProperty = "", alias = "ME_Message") })
  @ThingworxServiceDefinition(name = "OnMessageNew", description = "Subscription handler", category = "", isPrivate = true, isAllowOverride = false, aspects = { "isAsync:false" })
  public void OnMessageNew(
    @ThingworxServiceParameter(name = "events", description = "", baseType = "INFOTABLE") InfoTable events,
    @ThingworxServiceParameter(name = "thisSub", description = "", baseType = "INFOTABLE") InfoTable thisSub
    LOGGER.trace("Entering Service: OnMessageNew with:");
    LOGGER.trace("Exiting Service: OnMessageNew");
Still not everything clear (PTC please provide a more detailed explanation of Annotations and especially the aspects!), but it's running as intended ...
Hello, in your example I'd expect it to work like this:
	@ThingworxMultiEventSubscription(enabled = true, handler = "OnMessage", events = {
		@ThingworxSubscriptionEvent(source = "Thing1", eventName = "Message", sourceProperty = "", alias = "MessageFromThing1"),
		@ThingworxSubscriptionEvent(source = "Thing2", eventName = "Message", sourceProperty = "", alias = "MessageFromThing2")
	public ActorTS() {
Vilia (my company) | GitHub | LinkedIn
atondorf
(To:Constantine)
Hi Constantin,
