Hi All,
I would like to see in the Three Model Viewer the file from Creo (pvz format file).
Which extension should be loaded?
Many Thanks
BR
Dimitri
Hi Dimitri Bologna,
This looks like the same question as your other thread, Problem on widget Three Model Viewer. If not, let me know and we can look into this.
Assuming it's the same question, I've emailed the Author of ThingWorx Labs asking for their clarification. I'll let you know on the other thread what I hear back.
Tony
Hi there,
now you can import pvz files into 3d model viewer widget.
Version 1.4.310
kind regards,
Erik Schmidt / inray Industriesoftware
Hi @dbologna1.
If the previous response on this provided the solution, please mark it as the Accepted Solution for the benefit of others who may have the same question.
--Sharon
Where can I do I download 1.4.310. The one on the marketplace is 1.4.1
A\Anco
Hi
you can get this version from a ptc technical contact.
Otherwise I could make the version available to you.
Contact me at:
e.schmidt@inray.de
Kind regards,
Erik Schmidt // inray Industriesoftware
FYI, besides the latest 3-Model viewer extension that you can get from other TS members, there's another widget that can show a pvz file.
There is an extension/widget called ThingView in Winchill extension package, and it can present the pvz file properly. https://www.ptc.com/en/support/article?n=CS288755&posno=1&q=thingview&source=search
