Time Breakout Chart
wtaylor1
7-Bedrock
Time Breakout Chart
I am using ThingWorx Platform Release 9.3 and DatecodeSP9
I am using the Bar Chart widget and using it as a column chart. I need help developing the service to get the data into an infotable that will have runtime in minutes for every 20 minutes with planned downtime in certain columns (3-4). I have an example of what the customer wants it to look like.
CharlesJi
(To:wtaylor1)
Hi @wtaylor1 , I think you can try to use the Auto Refresh function to refresh the data source service to have it updated every 20 minutes.
Here is the example of the chart I am trying to populate:
Here is the Here is the code I am trying to use.
// Create a new service in ThingWorx
// Name: CreateRuntimeInfoTable
// Inputs: MashDate & Runtime_Min_Total
// Outputs: INFOTABLE (DataShape: RuntimeDataShape)
var result = Resources['InfoTableFunctions'].CreateInfoTableFromDataShape({
    infoTableName: "InfoTable",
    dataShapeName: "OEETImeBreakChart_DS",
  // Define the start time and end time
  var startTime = MashupDate;
  startTime.setHours(6, 0, 0, 0); // 6:00 AM
  var endTime = new Date();
  endTime.setHours(18, 0, 0, 0); // 6:00 PM
  // Define the interval in milliseconds (20 minutes)
  var interval = 20 * 60 * 1000;
  // Loop through the time range and add rows to the InfoTable
  for (var time = startTime.getTime(); time <= endTime.getTime(); time += interval) {
      // Query the Value Stream for the runtime value at the specific time
      var query = {
          oldestFirst: true,
          maxItems: 1,
          query: {
              filters: {
                type: "AND",
                filters: [
                    type: "EQ",
                    fieldName: "timestamp",
                    value: dateFormat(new Date(time), "00:00:000"),
                    type: "EQ",
                    fieldName: "Runtime_Min_Total",
                    value: Things["KepConn_TruLaserWeldNPP"].Runtime_Min_Total,
      var streamEntries = Things["KepConn_TruLaserWeldNPP"].QueryNamedPropertyHistory(query);
      var runtimeValue = 0;
      if (streamEntries.rows.length > 0) {
          runtimeValue = streamEntries.rows[0].Runtime_Min_Total; // Replace 'Runtime' with the actual property name
      var row = {
          timestamp: new Date(time),
          Runtime_Min_Total: runtimeValue
      result.AddRow(row);
  // Return the InfoTable
  var output = result;
