Hi!
I have submitted a timeseries model to Thingworx Analytics, and it has been running for a day without stopping. I have only about 4700 entries and look back size is 30, so it seems that should not take so long.
I would be very grateful if someone could advise any possible solutions or potential causes of such behaviour.
Hi Andrey
30 is actually a large number for the lookback size. Given the way ThingWorx Analytics processes this internally that will lead to a lot of processing indeed.
You should look at lowering this. Normally you should be able to set this parameter to 0, and ThingWorx Analytics will automatically sample between a lookback size of 2 4 8 or 16 to find the most appropriate ... as you see this still remain much lower than your 30.
Kind regards
Christophe
Hi Andrey
Kind regards
Christophe
Dear Christophe,
Thank you very much that helped.
Best regards,
Andrey
