How to export data table entries directly to Excel file rather than .CSV file without using data export extension tool?
Without the data export extension (https://marketplace.ptc.com/apps/193619/data-export-extension#!overview) it's not possible out of the box. Why not to use the extension?
The other options:
Carles.
The other options:
Carles.
Hi @Indhumathi_96.
If the suggestion provided by @CarlesColl allowed you to solve your issue, please mark it as the Accepted Solution for the benefit of others with the same question.
--Sharon
