Hi everyone,
I see in the tomcat logs the warning that you find in the attached file.
This is logged with high frequency and leads to run out of disk space and crash Thingworx.
The version of Thingworx 8.5.5
Thank you,
Best Regards
Hi @eazzarito ,
An browser is sending an HTTP request cookie that is not compliant with the ESAPI rules in place.
You may have to modify those rules.
You can find a detailed procedure in this article : https://www.ptc.com/en/support/article/CS270061
Hi @eazzarito ,
