Tomcat installation Java path Notes
veerasekar
8-Gravel
Hi All,
I have installed oracle Java software. after I install tomcat 8.5 which path name I write in System Environmental variable, Like jre or jdk.. Which one is correct.. Please consider me. And reply sir
Veerasekar
CharlesJi
(To:veerasekar)
Hi @veerasekar, if you are installing tomcat, the path of Java Virtual Machine would be jre (Java Runtime Environment).
e.g.,
C:\Program Files\Java\jdk1.8.0_92\jre
cmorfin
(To:veerasekar)
Hi @veerasekar
JAVA_HOME environment variable should point to the JDK, for example C:\Program Files\Java\jdk1.8.0_201, not the JRE.
Hope this helps
Christophe
CharlesJi
(To:veerasekar)
e.g.,
