I would like to upgrade Tomcat version without upgrading Thingworx version, currently my Tomcat version is 9.0.88 and it is showing as outdated by IT Department
Can we do anything my Thingworx version is 9.5.3
If I upgrade to Thingworx 10 I will get tomcat version 11
Here's how to do it: https://www.ptc.com/en/support/article/CS272588?
Release Advisor says supported version is 9.0.88 (here: https://release-advisor.ptc.com/releaseMatrix?releaseId=1865)
So you can update to the latest tomcat 9.0 release, currently 9.0.110.
If you want to go higher, you need to update ThingWorx to be on a supported platform.
Hello I have followed all the steps as mentioned in the article, I have installed the new tomcat 9.0.110 but my thingworx is still redirected to older tomcat version if I stop that thingworx page is not loading
Two questions
1) do we need to use older(9.0.88) web.xml and server.xml and copy into new tomcat webapps
2) I was not able to understand point 6 in the article https://www.ptc.com/en/support/article/CS272588
as it says directly copy the older ones and paste into new tomcat folder
VS
Point 19 and 20 says that we need to edit web.xml and server.xml
do we need to remove the older tomcat folder from
C:\Program Files (x86)\ThingWorxFoundation\tomcat
Hi @VV_9240359,
It appears that this post may answers your question. For the benefit of other Community Members who may have the same question, it would be great if you could designate it as the Accepted Solution.
In the event that this response did not answer your question, please post your current status so that we can continue to support.
Thanks for using the PTC Community!
Abhi
Hello Abhi,
I will work on this solution by referring to the documentation, the solution provided by Rocko has all the information in detail. Yes I have marked it as Solution
TWXDev
