Dec 13, 2018 1:24 PM UTC
Totaling valuestream - JSON does not allow non-finite numbers problem
I`m going trough  valuestream entries and filtering them and saving to infotable in a service.
Basicaly im totalling values between hour A to hour B on each day for a week.
Problem is I get error when i use:
Totall+= StreamValue;
Im getting error:
"Wrapped org.json.JSONException: JSON does not allow non-finite numbers. Cause: JSON does not allow non-finite numbers."
everythign works fine if I use Totall+=1 or Totall= StreamValue;  but  +=StreamValue makes a problem.
Code used:
var params = {
                oldestFirst: undefined /* BOOLEAN */,
                maxItems: undefined /* NUMBER */,
                endDate: undefined /* DATETIME */,
                query: undefined /* QUERY */,
                startDate: undefined /* DATETIME */
var data = me.QueryPropertyHistory(params);
var params = {
                infoTableName : "InfoTable",
                dataShapeName : "StorageDataShape_granicd"
var result = Resources["InfoTableFunctions"].CreateInfoTableFromDataShape(params);
var tableLength = data.rows.length;
var newEntry = new Object();
var Once=0;
for (var y = 0; y < 7; y++)
        var Type1=0;
        Once=0;
        newEntry.timestamp=null;
        for (var x = 0; x < tableLength; x++)
            var row=data.getRow(x);
            if(row.timestamp.getDay()===y && row.timestamp.getHours() >= FromHour && row.timestamp.getHours() < TillHour) //row.timestamp.getDay()==y
                if(Once==0)
                    newEntry.timestamp=row.timestamp;
                    Once=1;
                Type1+= row.LM;      //problem line
       newEntry.LM_Totall=Type1;
       result.AddRow(newEntry);
me.Totallhours=result;
Dec 19, 2018 2:57 PM UTC
Turns out problem was some properties in stream were NaN like error said(tho it refered to non-finite). I just needed to check in code first if they are NaN/empty then try to add them if they are not. 😕 Best way is "if(x!=x)"  x - some property value.
Dec 19, 2018 1:36 PM UTC
Hello @DavorGranic,
Not sure exactly where the problem in the code could be, but I was thinking that this article might help:
https://www.ptc.com/en/support/article?n=CS267063 (refering to JSON not allowing non-finite numbers)
DavorGranic16-PearlAuthorAnswer
Support
Dec 19, 2018 3:08 PM UTC
Hi @DavorGranic.
If you are satisfied with the solution you posted, please mark it as the Accepted Solution for the benefit of others with the same question.
Thank you for using our Community!
Regards.
--Sharon
