Is there any event that triggers on ThingWorx restart?
We need to call the subscription to update the current device status in the datatable after ThingWorx restart.
Hi @PG_CG ,
ThingStart event is the event that triggers with every thing. Also you can follow the belo given article to create custom event in ThingWorx:
https://www.ptc.com/en/support/article/cs224727
Kindly check an let me know if you find this useful.
Bhawna
Hi @PG_CG ,
Bhawna
