I am having an issue using the Twilio Extension. It was working with TWX 5.4, but we recently upgraded to TWX 6.0.2 and it is no longer working and giving an Error:
Forbidden content from [URL-To-Service]: application/x-www-form-urlencoded
I found a similar topic here: Why is CreateThing java REST call in R6 is failing with HTTP Error 403 Forbidden?
Using the information here, I have found that if I uncheck Filter Content-Type, then I can receive the messages without issue, but having it checked causes it to fail. Since this seems to be a security feature, is there something that can be done to get the Twilio Extension to work properly with that option checked?
Did you download the latest extensions as well as the platform?
I would try that first, if you already are on the latest extensions, i recommend you log a case on the support portal.
I have the latest extension, Package 2.0. I'll have to check about the platform. Last I knew I was using the latest one at 6.0.2.
