UTC to CDT Timezone
pshashipreetham
18-Opal
UTC to CDT Timezone
How to convert the UTC Date Time to CDT in thingworx ?
@paic @c_lowy @slangley
Shashi
Shashi Preetham,
+91 8099838001 | shashi@psptechhub.com,
PSPTechHub  ||  World of PTC Thingworx  ||  LinkedIn
After lot of manipulation in the TimeStamp with Thingworx and JS Functions was not able to get proper time zone, so used the Third Party API for this. Use the below Code:
var params = {
    proxyScheme: 'http' /* STRING */,
    headers: {"Accept-Encoding":"gzip, deflate, br","Accept":"*/*","Content-Type": "application/json"},
    ignoreSSLErrors: true,
	url: "http://worldtimeapi.org/api/timezone/America/Chicago" /* STRING */,
// result: JSON
var CDTdate = Resources["ContentLoaderFunctions"].GetJSON(params);
//date = CDTdate.datetime;
date = ((CDTdate.datetime).split("T")[0]);
time = ((CDTdate.datetime).split("T")[1]);
timestamp = ((time).split(".")[0]);
hours = timestamp.split(":")[0];
if(hours > 12 ){
    result = date + " " + timestamp + " PM  CDT";
else{
    result = date + " " + timestamp + " AM  CDT";
Shashi
Shashi Preetham,
4 REPLIES 4
If you have a 'fixed' offset, you can just apply the offset.
If you don't know the offset, you'll somehow have to determine the 'locale' and then apply the offset.
Since client side automatically converts to client side local time, you'll also have to keep that in mind when doing the offset.
I recommend a simple google search for javascript converting date time to another timezone
If it is a fixed offset though, there are the date time code snippets so you can do 'datetimeaddhours'
Hi @PaiChung ,
Thanks for Quick Response, but tried in all ways, nothing helped, therefore reached out for the community !!
Shashi
Shashi Preetham,
Can you perhaps describe in more detail the situation you are facing?
When and where do you receive/have the data stored that needs to be converted, as well as for what reason?
var params = {
// result: JSON
if(hours > 12 ){
else{
Shashi
Shashi Preetham,
