Hi All,
Just a small, quick one...
Does anyone know how to access the comments you have made when saving an Entity with Comments? (The little button next to "Save" at the top of the Entity)
I have tried looking at "Change History" but it doesn't display my custom comments. Maybe I have not configured something properly?
Many Thanks
Ashley
Ashley, it should be accessible via the Change History for that particular Thing. What kind of user permission are you using to login? There are no special settings needed if you are login as Administrator, it should be visible by selecting the Thing and Viewing it something like this and you can see the comments i created for testing under the Change History
Hope this helps.
Hope this helps.
For some reason it has worked now. Not sure what I did wrong to start with though!
