The system complaints that "This entity does not support property permissions"
Exception:
Wrapped java.lang.Exception: This entity does not support property permissions Cause: This entity does not support property permissions
Here under is a code to simulate the case
var EntityServices = Resources['EntityServices'] var newTemplateName = 'TestThingTemplate' if (ThingTemplates[newTemplateName]) EntityServices.DeleteThingTemplate({ name: newTemplateName })
EntityServices.CreateThingTemplate({name: newTemplateName, thingTemplateName: 'RemoteThing' }) ThingTemplates[newTemplateName].AddRunTimePermission({ principalType : "Group", principal : "Users", allow : true, type : "PropertyRead", resource : "*" })
My Bests,
Hung Tran
Anyway, the Instance Runtime Permission should be implemented behind the scenes in order to keep the security scheme to be consistent and simple for use.
