I was just able to install 5.0SP successfully. After imported data from our old development server I was not able to log into our DEV area using active directory. We have two LDAP objects and both are enabled. Tomcat has been restarted.
Security Log Entry:
Authentication attempt #1 FAILED for /user = com.thingworx.security.users.User@2c9a7578: Invalid Password
Hi Sinh,
No error in the application log. Yes. I'm able to log in using Thingworx credential.
Sinh,
We added an "Enabled" flag for Directory Services in 5.0. Please make sure this checkbox is selected on the General Information screen for the Directory Service.
Thanks.
Partner Callisto created something for LDAP integration with ThingWorx...worth a look, Duke Sullivan is their current partner manager within PTC. Duke Sullivan
Callisto’s extension is for Active Directory (AD).
Thanks for the correction....given the integration options for AD and LDAP, maybe a better ThingWorx integration option would be something like Okta? Maybe Callisto can look into that? If the opportunity is large enough, this is something an SI could tackle as well.
