I am using the Hosted Server for evaluation. The server status shows running, when I try to launch it shows pp-1808241816mn.devportal.ptc.io refused to connect.
Please help me on what the problem is.
Hi @cnuga sorry for the trouble are you still not able to access the instance?
I have switched to local server. Haven't tried the rest API on local server.
Check out the upcoming Expert Session: Understanding ThingWorx Navigate Licensing in Community "Customer Events" section.
