Unable to control keyboard enter in combo box/drop down
BhavyaPC
Hi All,
I'm using a combo box  widget in my mashup for a requirement which has to take text input, based on the input it has to provide suggestions. The requirement is to provide a search engine.
With the combo box,  I'm unable to achieve the requirement. If I paste some text in the widget and and as soon as I Press enter the value is getting vanished. kindly someone let me know how to control Enter pressed event in this widget? or Please let me know how to achieve search engine with the available widgets.
Thanks In Advance
slangley
(To:BhavyaPC)
Hi @BhavyaPC.
If we're understanding your need, we think you can do this using the Autocomplete widget.  Depending on the version of ThingWorx you are running, you may already have this installed.  If not, it's available from the PTC Marketplace.
Regards.
--Sharon
slangley
(To:slangley)
Hi @BhavyaPC.
If the previous response answered your question, please mark it as the Accepted Solution for the benefit of others with the same question.
Regards.
--Sharon
