Unable to filter infotable inside foreach/for loop ?
akesana
We have two infortables
infotable1 contains 50 records
infotable2 contains 3 records we want to get maching records of all in for each way. Please find below logic we have written
var tableLength = infotable1 .rows.length;
    for(var z = 0; z < tableLength; z++)
        var row=infotable1.rows;
var params = {
     fieldName: "source_number" /* STRING */,
      isCaseSensitive: undefined /* BOOLEAN */,
      t: infotable2 /* INFOTABLE */,
      value: row.source_number /* STRING */   // If I pass this I am getting empty result if I pass hardcoded value it works fine
   // result: INFOTABLE
  var result = Resources["InfoTableFunctions"].EQFilter(params);
Colud you check is anything worng in my code?
Anil Kesana
Try Intersect Snippet instead
Hi Carles,
Thanks for your quick response, I have tried but not worked source_number in both table is string.
we need to filter based on that string field of every row of infotable1 and get matcing row of infotable2
Anil Kesana
Hi Anil,
With Intersect snippet you will need something like:
var result = Resources["InfoTableFunctions"].Intersect({
  columns1: "",
  columns2: "*",
  joinType: "INNER",
  t1: infotable1,
  t2: infotable2,
  joinColumns1: "source_number",
  joinColumns2: "source_number"
Hi Carles,
Thanks Carles, It  worked for me I would like to check and condition on multiple columns is is it  possible like below?
  1. var result = Resources["InfoTableFunctions"].Intersect({
  2.   columns1: ""
  3.   columns2: "*"
  4.   joinType: "INNER"
  5.   t1: infotable1,
  6.   t2: infotable2,
  7.   joinColumns1: "source_number"&&"plant_id"&&"note_id"
  8.   joinColumns2: "source_number"&&"plant_id"&&"note_id"
  9. });
I got weird result when execute the above the code, how to check and condition ?
Anil Kesana
Separate columns by commas
