This is not a Thingworx importable extension .The ThingWorx Java Client SDK contains the required Java libraries(JARs) for writing a client in Java that is capable of communicating with the ThingWorx Server. It also contains a sample which you can import/use in eclipse and create a client to connect to ThingWorx .
Mukul Narang
Mukul Narang
Hi @Dabbler_Aish,
If you were able to resolve your issue, please post it here and mark it as the Accepted Solution for the benefit of others on the community. If you are still experiencing issues, please do let us know your questions or concerns, thanks
vangne
