Thingworx 8.5.2 :
I have increased width and height of checkbox widget but couldn't increase it's size more than default size.Could you help me.
Is this the type of change you would like to be able to accomplish?
I used the Visual SDK and added Custom CSS to the mashup:
#root_ptcscheckbox-13.widget-ptcscheckbox::part(box){
width: 28px;
height: 28px;
#root_ptcscheckbox-13.widget-ptcscheckbox::part(check-mark) {
width: 28px;
height: 28px;
#root_ptcscheckbox-14.widget-ptcscheckbox::part(box){
width: 56px;
height: 56px;
#root_ptcscheckbox-14.widget-ptcscheckbox::part(check-mark) {
width: 56px;
height: 56px;
In my test case the IDs of the second and third check box are "ptcscheckbox-13" and "ptcscheckbox-14". I included a second CSS to increase the size of the check to match the box. If you wanted the modification applied to all the checkbox's you would not need the "#" and the item ID.
HTH
Peter
width: 28px;
height: 28px;
width: 28px;
height: 28px;
width: 56px;
height: 56px;
width: 56px;
height: 56px;
HTH
Peter
