Unable to load DLL 'twApi.dll' error running SteamSensor in docker
srajgopal
3-Visitor
Downloaded the .NET SDK and everything works fine on my windows 10 laptop.
But when running the exact same bits in a docker container, getting this error. I have tried various images such as
microsoft/aspnet
mcr.microsoft.com/dotnet/framework/sdk:4.8
docker pull mcr.microsoft.com/dotnet/framework/runtime:4.8
mcr.microsoft.com/windows/servercore:10.0.16299.1029
com.thingworx.communications.client.TwApiWrapper Error: 0 : Error initializing the .NET SDK. : System.DllNotFoundException: Unable to load DLL 'twApi.dll': The specified module could not be found. (Exception from HRESULT: 0x8007007E)
at com.thingworx.communications.client.TwApiWrapper.twW_SetLoggerProperties(TwApiLogLevel level, Byte isVerboseEnabled, TwLogMessageDelegate onLogMessage)
at com.thingworx.communications.client.TwApiWrapper.ConfigureTwApiLogger()
at com.thingworx.communications.client.TwApiWrapper.Initialize(ClientConfigurator config)
Unhandled Exception: System.DllNotFoundException: Unable to load DLL 'twApi.dll': The specified module could not be found. (Exception from HRESULT: 0x8007007E)
at com.thingworx.communications.client.ConnectedThingClient..ctor(ClientConfigurator config)
at SteamSensorConsole.SteamSensorClient..ctor(ClientConfigurator config) in C:\Users\rshrini\samples\Dotnet-SDK-5-7-6-3407-win\Example\SteamSensorConsole\SteamSensorClient.cs:line 19
at SteamSensorConsole.SteamSensorClient.Main(String[] args) in C:\Users\rshrini\samples\Dotnet-SDK-5-7-6-3407-win\Example\SteamSensorConsole\SteamSensorClient.cs:line 91
After installing the that Microsoft Visual C++ Redistributable for Visual Studio 2012, it works.
