Unable to push the sensor output to the thingworx database
dm-21
Presently i'm working on an example IoT project (Temperature and Humidity measurement using Arduino Uno), I got the sensor output using Arduino IDE but unable to see the output in properties section in the Thingworx database. I have followed all the procedures given in the instruction manual. And the second thing is i'm unable to find the Mail Server Template in the Thing Template. Can anyone suggest me, what might be the problem?
vmihai
(To:dm-21)
Can you please post a print screen of your Arduino IDE Serial Monitor with the REST calls that are being sent to ThingWorx ?
The Mail Server needs to be imported separately. You can download it from the market place at this url
ThingWorx IoT Marketplace » Mail
Thank you,
Veronica
10 REPLIES 10
vmihai
(To:dm-21)
Thank you,
Veronica
dm-21
(To:vmihai)
Thanks alot Veronica
dm-21
(To:dm-21)
//#include <Dhcp.h>
//#include <Dns.h>
#include <Ethernet.h>
#include <EthernetClient.h>
#include <EthernetServer.h>
//#include <EthernetUdp.h>
#include <SPI.h>
#include "SparkFunHTU21D.h"
// #include <HTU21D.h>
#include <Wire.h>
//How many values you will be pushing to ThingWorx
#define propertyCount 2
// Enter a MAC address and IP address for your controller below.
// The IP address will be dependent on your local network:
byte mac[] = {0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED};
char server[] = "ge2-4664.cloud.thingworx.com";
EthernetClient client;
//ThingWorx App key which replaces login credentials)
char appKey[] = "60cd9a5e-04e2-4e26-b7b9-f457cd91e774";
// ThingWorx Thing name for which you want to set properties values
char thingName[] = "HTU21DThing";
//Interval of time at which you want the properties values to be sent to TWX server
int timeBetweenRefresh = 5000;
// ThingWorx service that will set values for the properties you need
// See the documentation for this tutorial for more information
char serviceName[] = "setTempAndHumid";
//Initialize Properties Names and Values Arrays
char* propertyNames[] = {"Temp" , "Humid"};
double propertyValues[propertyCount];
// last time you connected to the server, in milliseconds
unsigned long lastConnectionTime = 0;
// state of the connection last time through the main loop
boolean lastConnected = false;
//Initialize an HTU21D library object to read
// temperature and humidity data from your connected sensor
HTU21D myHumidity;
void setup() {
  //shut down the SD Card pins
  pinMode(4,OUTPUT);
  digitalWrite(4,HIGH);
  // start serial port:
  Serial.begin(9600);
  while (!Serial) {
    ; // wait for serial port to connect. Needed for Leonardo only
  //initialize HTU21D object to read values from sensors
   myHumidity.begin();
  // start the Ethernet connection:
  Serial.println("Trying to get an IP address using DHCP");
  Ethernet.begin(mac);
  Serial.print("My IP address: ");
  Serial.print(Ethernet.localIP());
  Serial.println();
void loop() {
  // Aquire sensor values
  propertyValues[0] = myHumidity.readTemperature();
  propertyValues[1] = myHumidity.readHumidity();
  // wait the established interval of time before
  // reading values from the sensor
  // and sending them to the TWX server again
delay(timeBetweenRefresh);
if (millis() - lastConnectionTime > timeBetweenRefresh) {
updateValues(propertyValues, client, server, appKey, thingName, serviceName, propertyNames);
void updateValues(double values[] , EthernetClient &client, char server[], char appKey[], char thingName[], char serviceName[], char* sensorNames[])
  //build the String with the data that you will send
  //through REST calls to your TWX server
  char data[80];
  strcpy(data, "?appKey=");
  strcat(data, appKey);
  strcat(data, "&method=post&x-thingworx-session=true");
  // if you get a connection, report back via serial:
  if (client.connect(server, 80)) {
    Serial.println("connected");
    // send the HTTP POST request:
    client.print("POST /Thingworx/Things/");
    client.print(thingName);
    client.print("/Services/");
    client.print(serviceName);
    client.print(data);
    client.print("<");
    for (int idx = 0; idx < propertyCount; idx++)
      client.print("&");
      client.print(propertyNames[idx]);
      client.print("=");
      client.print(propertyValues[idx]);
    client.print(">");
    client.println(" HTTP/1.1");
    client.print("Host: ");
    client.println(server);
    client.println("Content-Type: text/html");
    client.println();
     client.stop();
    lastConnectionTime = millis();
    // print the request out
    Serial.print("POST /Thingworx/Things/");
    Serial.print(thingName);
    Serial.print("/Services/");
    Serial.print(serviceName);
    Serial.print(data);
    Serial.print("<");
      Serial.print("&");
      Serial.print(propertyNames[idx]);
      Serial.print("=");
      Serial.print(propertyValues[idx]);
    Serial.print(">");
    Serial.println(" HTTP/1.1");
    Serial.print("Host: ");
    Serial.println(server);
    Serial.println("Content-Type: text/html");
    Serial.println();
  else {
    // kf you didn't get a connection to the server:
    Serial.println("the connection could not be established");
    client.stop();
vmihai
(To:dm-21)
I see that you are using ThingWorx 6.0  The tutorial was developed on ThingWorx 5.2 and there is an additional step to  be done on ThingWorx 6.0 to make it work. You need to enable REST calls  by following these steps :
1.           Click on Subsystems under SYSTEM within the left pane of Composer
2.            Click on PlatformSubsystem
3.            Click on Configuration
4.            Check the box next to Allow Request Method Switch to allow all REST API calls through a browser URL
5.            Uncheck Filter Content-Type
Let me know if this fixes the issue,
Thank you,
Veronica
dm-21
(To:vmihai)
Hai Good Morning Veronica,
It is working fine now,  i can able to see the updating values in my property.
Thank you so much for your great support veronica.
Dhivya
dm-21
(To:dm-21)
Hai,
I have an other doubt veronica, my label chart is not showing the graph in the Mashup view page.
I have uploaded the .ino file again and i have done refresh also. Can u please help me?
dm-21
(To:vmihai)
Hai,
I have an other doubt, my label chart is not showing the graph in the Mashup view page.
vmihai
(To:dm-21)
Hi Dhivya,
Can you please verify if your data has been properly logged in the value stream that you assigned to your HTU21DThing ? You can do this by going to the services section of the HTU21DThing and testing the QueryPropertyHistory General service.
If you can see the values for the logged properties  as shown below, than your Stream is properly set up.
If you cannot see any property, please first verify that your properties are being properly sent to ThingWorx, by running the sketch on your Arduino and going to the Properties section of the HTU21DThing and hitting the update button. If the properties are being updated, follow the instructions for setting up your logged properties described in this tutorial starting from page 2. http://www.thingworx.com/-/media/Files/PDFs/Academics/32AUHowtoCreateaMashupforArduinoUnoStep2.pdf?la=en
Let me know if you are in need of further assistance.
Thank you,
Veronica
dm-21
(To:vmihai)
Hai Veronica,
Thanks a lot for your precious guidance, i got the proper output with the graph.
Thank you,
Dhivya
fdasilva
(To:dm-21)
Hi Veronica,
I am facing the same problem. The serial monitor shows the correct POST method but the properties are not being updated.
I am using the Composer 7.3.2.
The code is:
#include <DHT.h>
//#include <HTU21D.h>
#include <Wire.h>
Arduino to Thingworx Ethernet Web Client using Ethernet Shield
This sketch reads sensor values and sends the values to a Thing on ThingWorx.
The sketch uses the Ethernet Repeating Web client (info below) and a custom ThingWorx library
as a starting point.  The user must choose a unique MAC address (the sketch right now
is set up as DHCP but you can add Static IP and DNS if you'd like.  Just make sure you
relay those changes in the Ethernet.begin() call).  On the Thingworx side make sure your
nameArray[] values, your thingName[], your serviceName[] and your server[] matches exactly.
Use your provided appKey that you recieve when you set up your Thing.
Create a service in your Thing or ThingShape and create inputs that will match the variable names you use
in your Arduino code.  In the JavaScript window type something similar to the following:
me.PropertyOne = parseFloat(InputOne);
me.PropertyTwo = parseFloat(InputTwo);
Where Property one is the name of your first Thing or ThingShape property and InputOne is the name of
your first input.  Everything is case sensitive.
Update sensorCount to reflect how many sensors (or whatever data variables) you want to
send.
created 3/5/2015
by Nick Milleson
Design Engineer
EAC Product Development Solutions
www.eacpds.com
nmilleson@eacpds.com
This sketch connects to a a web server and makes a request
using a Wiznet Ethernet shield. You can use the Arduino Ethernet shield, or
the Adafruit Ethernet shield, either one will work, as long as it's got
a Wiznet Ethernet module on board.
This example uses DNS, by assigning the Ethernet client with a MAC address,
IP address, and DNS address.
Circuit:
* Ethernet shield attached to pins 10, 11, 12, 13
created 19 Apr 2012
by Tom Igoe
http://arduino.cc/en/Tutorial/WebClientRepeating
This code is in the public domain.
#include <SPI.h>
#define DHTPIN 2     // what digital pin we're connected to
#define DHTTYPE DHT11   // DHT 11
char server[] = "http://pp-20170404234723327.portal.ptc.io/Thingworx";
char appKey[] = "51884259-1003-444a-b361-485668d595ec";
char thingName[] = "HTD11Thing";
char* propertyNames[] = {"Temp", "Humid"};
//HTU21D myHumidity;
DHT myHumidity(DHTPIN, DHTTYPE);
void setup() {
//pinMode(4,OUTPUT);
//digitalWrite(4,HIGH);
  Serial.begin(9600);
  while (!Serial) {
   myHumidity.begin();
  Serial.println();
void loop() {
  char data[80];
client.connect(server, 80);
    Serial.println("HTD11Thing");
    Serial.println("setTempAndHumid");
    client.print("HTD11Thing");
    client.print("setTempAndHumid");
    client.print(data);
    client.print("<");
      client.print("&");
      client.print("=");
    client.print(">");
    client.println();
     client.stop();
    Serial.print("HTD11Thing");
    Serial.print("setTempAndHumid");
    Serial.print(data);
    Serial.print("<");
      Serial.print("&");
      Serial.print("=");
    Serial.print(">");
    Serial.println();
  else {
    // if you didn't get a connection to the server:
    client.stop();
Any ideas? I have read all information on internet and try everything.
Thanks in advance!
Felipe da Silva
