Unable to read properties from a remote thing in Thingworx
samyelbouziani
Hi team,
I have connected an asset to KepServerEX (version 6.2) and I am currently trying to push data from KepServerEX to Thingworx platform using existing Things (version 8).
As you can see in "quickClient" and "ThingworxProperties" screenshots attached, the data are well retrieved in KepServerEX. The Thingworx connection properties are also good and the connection is established with the platform.
In Thingworx, I manage the bindings correctly  by going to New Composer -> BearingFaultSimulatorRemote thing-> properties-> manage bindings (see "manageBindings_thingworx" screenshot attached).
Unfortunately I can't get data in Thingworx and I get the same error message for all the variables by going to application monitoring logs (see "error_thingworx" screenshot attached) :
"Error reading property [thing: BearingFaultSimulatorRemote, property: Bearing***] No return from Property Read Request"
I already spent some time trying to solve it by restarting servers, changing parameters...in vain.
Can you guys help me on how to fix this issue?
Thanks in advance,
Samy El Bouziani
0 REPLIES 0
