I am using Java SDK to push data into thingworx. I created a thing in Core with the name same as that of thing in JAVA SDK. When I start my SDK , the connection between Core and SDK is established and I see that isConnected property of remote thing is set to true. After few seconds the connection drops/closed and I am unable to do manage bindings for remote thing which is required to capture values from SDK. Below are the logs. Can anyone help me to whats wrong I have done here.
NOTE : I am using trial version of thingworx foundation server that is on remote machine.
15:55:39.431 [main] INFO c.s.v.s.MasterClientConfigurator - Reading from file
15:55:39.435 [main] INFO c.s.v.s.MasterClientConfigurator - Thingworx webservice url isws://13.113.122.50:80/Thingworx/WS
15:55:39.514 [main] INFO c.t.c.c.p.ClientMessageProcessor - Created new ClientMessageProcessor [minPoolSize: 4, maxPoolSize: 10, maxThreadLife: 10000, maxQueueSize: 1000]
URL: ws://13.113.122.50:80/Thingworx/WS
AppKey: 261c61e2-10c7-4635-97d4-6d367771bd1d
15:55:39.576 [main] DEBUG i.n.u.i.l.InternalLoggerFactory - Using SLF4J as the default logging framework
15:55:39.579 [main] DEBUG i.n.c.MultithreadEventLoopGroup - -Dio.netty.eventLoopThreads: 4
15:55:39.588 [main] DEBUG i.n.util.internal.PlatformDependent0 - java.nio.Buffer.address: available
15:55:39.588 [main] DEBUG i.n.util.internal.PlatformDependent0 - sun.misc.Unsafe.theUnsafe: available
15:55:39.589 [main] DEBUG i.n.util.internal.PlatformDependent0 - sun.misc.Unsafe.copyMemory: available
15:55:39.589 [main] DEBUG i.n.util.internal.PlatformDependent0 - java.nio.Bits.unaligned: true
15:55:39.589 [main] DEBUG i.n.util.internal.PlatformDependent - Platform: Windows
15:55:39.589 [main] DEBUG i.n.util.internal.PlatformDependent - Java version: 8
15:55:39.590 [main] DEBUG i.n.util.internal.PlatformDependent - -Dio.netty.noUnsafe: false
15:55:39.590 [main] DEBUG i.n.util.internal.PlatformDependent - sun.misc.Unsafe: available
15:55:39.590 [main] DEBUG i.n.util.internal.PlatformDependent - -Dio.netty.noJavassist: false
15:55:39.591 [main] DEBUG i.n.util.internal.PlatformDependent - Javassist: unavailable
15:55:39.591 [main] DEBUG i.n.util.internal.PlatformDependent - You don't have Javassist in your class path or you don't have enough permission to load dynamically generated classes. Please check the configuration for better performance.
15:55:39.591 [main] DEBUG i.n.util.internal.PlatformDependent - -Dio.netty.tmpdir: C:\Users\EE209924\AppData\Local\Temp (java.io.tmpdir)
15:55:39.592 [main] DEBUG i.n.util.internal.PlatformDependent - -Dio.netty.bitMode: 64 (sun.arch.data.model)
15:55:39.592 [main] DEBUG i.n.util.internal.PlatformDependent - -Dio.netty.noPreferDirect: false
15:55:39.614 [main] DEBUG io.netty.channel.nio.NioEventLoop - -Dio.netty.noKeySetOptimization: false
15:55:39.615 [main] DEBUG io.netty.channel.nio.NioEventLoop - -Dio.netty.selectorAutoRebuildThreshold: 512
15:55:39.902 [main] DEBUG i.n.buffer.PooledByteBufAllocator - -Dio.netty.allocator.numHeapArenas: 2
15:55:39.903 [main] DEBUG i.n.buffer.PooledByteBufAllocator - -Dio.netty.allocator.numDirectArenas: 2
15:55:39.903 [main] DEBUG i.n.buffer.PooledByteBufAllocator - -Dio.netty.allocator.pageSize: 8192
15:55:39.903 [main] DEBUG i.n.buffer.PooledByteBufAllocator - -Dio.netty.allocator.maxOrder: 11
15:55:39.903 [main] DEBUG i.n.buffer.PooledByteBufAllocator - -Dio.netty.allocator.chunkSize: 16777216
15:55:39.904 [main] DEBUG i.n.buffer.PooledByteBufAllocator - -Dio.netty.allocator.tinyCacheSize: 512
15:55:39.904 [main] DEBUG i.n.buffer.PooledByteBufAllocator - -Dio.netty.allocator.smallCacheSize: 256
15:55:39.904 [main] DEBUG i.n.buffer.PooledByteBufAllocator - -Dio.netty.allocator.normalCacheSize: 64
15:55:39.904 [main] DEBUG i.n.buffer.PooledByteBufAllocator - -Dio.netty.allocator.maxCachedBufferCapacity: 32768
15:55:39.904 [main] DEBUG i.n.buffer.PooledByteBufAllocator - -Dio.netty.allocator.cacheTrimInterval: 8192
15:55:39.912 [main] DEBUG c.t.c.c.e.m.CommunicationEndpointMonitorTask - Initializing CommunicationEndpoint Connection Monitor...
15:55:39.913 [Client-EndpointMonitor-1] DEBUG c.t.c.c.e.m.CommunicationEndpointMonitorTask - CommunicationEndpoint Monitor - checking for disconnected endpoints
15:55:39.913 [Client-EndpointMonitor-1] INFO c.t.c.c.e.m.CommunicationEndpointMonitorTask - Endpoint not connected [name: EP_0, id: 0]. Attempting [re]connect...
15:55:39.913 [Client-EndpointMonitor-1] DEBUG c.t.c.c.e.ClientCommunicationEndpoint - Clearing endpoint authentication data [id: 0]
15:55:39.913 [Client-EndpointMonitor-1] INFO c.t.c.c.e.ClientCommunicationEndpoint - Needed to refill connections on client endpoint [id: 0] : [active: 0, max: 1]
15:55:39.938 [Client-EndpointMonitor-1] DEBUG i.n.util.internal.ThreadLocalRandom - -Dio.netty.initialSeedUniquifier: 0xce958c169b1305ea (took 6 ms)
15:55:39.956 [Client-EndpointMonitor-1] DEBUG io.netty.buffer.ByteBufUtil - -Dio.netty.allocator.type: unpooled
15:55:39.957 [Client-EndpointMonitor-1] DEBUG io.netty.buffer.ByteBufUtil - -Dio.netty.threadLocalDirectBufferSize: 65536
15:55:39.995 [NettyClient-NIO-1] DEBUG io.netty.util.ResourceLeakDetector - -Dio.netty.leakDetectionLevel: simple
15:55:40.141 [NettyClient-NIO-1] DEBUG c.t.c.c.c.n.ThingworxClientConnectionHandler - WebSocket Channel is connected [is open: true]
15:55:40.146 [NettyClient-NIO-1] DEBUG i.n.h.c.h.w.WebSocketClientHandshaker13 - WebSocket version 13 client handshake key: 6Ky2JOcK4dsL0SGBOhTbBQ==, expected response: 02QmLnbUro0DCSQ9dI2vIJoCu4E=
15:55:40.154 [NettyClient-NIO-1] DEBUG io.netty.util.Recycler - -Dio.netty.recycler.maxCapacity.default: 262144
15:55:40.335 [NettyClient-NIO-1] DEBUG c.t.c.c.c.n.ThingworxClientConnectionHandler - [ClientHandler: 458191046] Client websocket handshake is complete
15:55:40.338 [Client-EndpointMonitor-1] INFO c.t.c.c.e.ClientCommunicationEndpoint - Preparing new Connection Authentication Request: DispatchingClientEndpoint [id: 0, isConnected: false, open connections: 0, max connections: 1]
15:55:40.339 [Client-EndpointMonitor-1] DEBUG c.t.c.c.e.CommunicationEndpoint - Sending connection authentication message, waiting for response [message: AuthRequestMessage [requestId: 1, endpointId: -1, sessionId: -1, method: AUTHREQUEST]]
15:55:40.345 [NettyClient-NIO-1] DEBUG i.n.h.c.h.w.WebSocket08FrameEncoder - Encoding WebSocket Frame opCode=2 length=60
15:55:40.476 [NettyClient-NIO-1] DEBUG i.n.h.c.h.w.WebSocket08FrameDecoder - Decoding WebSocket Frame opCode=2
15:55:40.476 [NettyClient-NIO-1] DEBUG i.n.h.c.h.w.WebSocket08FrameDecoder - Decoding WebSocket Frame length=17
15:55:40.496 [NettyClient-NIO-1] DEBUG c.t.c.c.e.DispatchingClientEndpoint - RESPONSE received [endpoint id: 0, duration: 157] ResponseMessage [requestId: 1, endpointId: 30, sessionId: 30, code: STATUS_SUCCESS, multipart: false, packet #: 0, total packets: 0]
15:55:40.497 [Client-EndpointMonitor-1] INFO c.t.c.c.e.ClientCommunicationEndpoint - Authentication Request was SUCCESSFUL [tworx session id: 30, connection group id: 30]
15:55:40.498 [Client-EndpointMonitor-1] DEBUG c.t.c.c.e.CommunicationEndpoint - [Endpoint id: 0, connection id: 0-0] added Connection
15:55:40.500 [Client-EndpointMonitor-1] INFO c.t.c.c.e.ClientCommunicationEndpoint - Successfully reconnected client endpoint [id: 0] : [active: 1, max: 1]
15:55:40.501 [Client-EndpointMonitor-1] INFO c.t.c.client.ConnectedThingClient - Communications Endpoint Opened
15:55:40.506 [Client-EndpointMonitor-1] DEBUG c.t.c.c.e.CommunicationEndpoint - Sending synchronous message, waiting for response [message: BindRequestMessage [requestId: 2, method: BINDREQUEST, names: [EP_0, RemoteRollingStock, EP_0]]]
15:55:40.508 [NettyClient-NIO-1] DEBUG i.n.h.c.h.w.WebSocket08FrameEncoder - Encoding WebSocket Frame opCode=2 length=63
15:55:40.644 [NettyClient-NIO-1] DEBUG i.n.h.c.h.w.WebSocket08FrameDecoder - Decoding WebSocket Frame opCode=2
15:55:40.644 [NettyClient-NIO-1] DEBUG i.n.h.c.h.w.WebSocket08FrameDecoder - Decoding WebSocket Frame length=17
15:55:40.914 [NettyClient-NIO-1] DEBUG c.t.c.c.e.DispatchingClientEndpoint - RESPONSE received [endpoint id: 0, duration: 408] ResponseMessage [requestId: 2, endpointId: -1, sessionId: -1, code: STATUS_SUCCESS, multipart: false, packet #: 0, total packets: 0]
15:55:40.914 [Client-EndpointMonitor-1] INFO c.t.c.c.e.m.CommunicationEndpointMonitorTask - Endpoint reconnected [name: EP_0, id: 0]
15:55:41.640 [NettyClient-NIO-1] DEBUG i.n.h.c.h.w.WebSocket08FrameDecoder - Decoding WebSocket Frame opCode=2
15:55:41.640 [NettyClient-NIO-1] DEBUG i.n.h.c.h.w.WebSocket08FrameDecoder - Decoding WebSocket Frame length=45
15:55:41.642 [NettyClient-NIO-1] DEBUG i.n.h.c.h.w.WebSocket08FrameDecoder - Decoding WebSocket Frame opCode=2
15:55:41.644 [NettyClient-NIO-1] DEBUG i.n.h.c.h.w.WebSocket08FrameDecoder - Decoding WebSocket Frame length=45
15:55:41.651 [NettyClient-NIO-1] DEBUG c.t.c.c.e.DispatchingClientEndpoint - API REQUEST received [endpoint id: 0] APIRequestMessage [requestId: 89, endpointId: -1, sessionId: -1, method: POST, entityName: EP_0, characteristic: Unknown, target: ]
15:55:41.655 [NettyClient-NIO-1] DEBUG i.n.h.c.h.w.WebSocket08FrameDecoder - Decoding WebSocket Frame opCode=2
15:55:41.657 [NettyClient-NIO-1] DEBUG i.n.h.c.h.w.WebSocket08FrameDecoder - Decoding WebSocket Frame length=59
15:55:41.662 [NettyClient-NIO-1] DEBUG c.t.c.c.e.DispatchingClientEndpoint - API REQUEST received [endpoint id: 0] APIRequestMessage [requestId: 87, endpointId: -1, sessionId: -1, method: POST, entityName: EP_0, characteristic: Unknown, target: ]
15:55:41.663 [NettyClient-NIO-1] DEBUG c.t.c.c.e.DispatchingClientEndpoint - API REQUEST received [endpoint id: 0] APIRequestMessage [requestId: 88, endpointId: -1, sessionId: -1, method: POST, entityName: RemoteRollingStock, characteristic: Unknown, target: ]
15:55:41.657 [ClientProcessor-1] DEBUG c.t.c.c.e.CommunicationEndpoint - Sending synchronous message, waiting for response [message: APIRequestMessage [requestId: 3, endpointId: 0, sessionId: 30, method: POST, entityName: EP_0, characteristic: Services, target: GetPropertySubscriptions]]
15:55:41.667 [NettyClient-NIO-1] DEBUG i.n.h.c.h.w.WebSocket08FrameEncoder - Encoding WebSocket Frame opCode=2 length=49
15:55:41.667 [ClientProcessor-2] DEBUG c.t.c.c.e.CommunicationEndpoint - Sending synchronous message, waiting for response [message: APIRequestMessage [requestId: 4, endpointId: 0, sessionId: 30, method: POST, entityName: EP_0, characteristic: Services, target: GetPropertySubscriptions]]
15:55:41.670 [ClientProcessor-3] DEBUG c.t.c.c.e.CommunicationEndpoint - Sending synchronous message, waiting for response [message: APIRequestMessage [requestId: 5, endpointId: 0, sessionId: 30, method: POST, entityName: RemoteRollingStock, characteristic: Services, target: GetPropertySubscriptions
15:55:41.671 [NettyClient-NIO-1] DEBUG i.n.h.c.h.w.WebSocket08FrameEncoder - Encoding WebSocket Frame opCode=2 length=49
15:55:41.677 [NettyClient-NIO-1] DEBUG i.n.h.c.h.w.WebSocket08FrameEncoder - Encoding WebSocket Frame opCode=2 length=63
15:55:41.802 [NettyClient-NIO-1] DEBUG i.n.h.c.h.w.WebSocket08FrameDecoder - Decoding WebSocket Frame opCode=2
15:55:41.803 [NettyClient-NIO-1] DEBUG i.n.h.c.h.w.WebSocket08FrameDecoder - Decoding WebSocket Frame length=223
15:56:00.905 [NettyClient-NIO-1] INFO c.t.c.c.c.n.NettyClientConnection - [websocket id: 0-0] Closing underlying websocket channel
15:56:00.906 [NettyClient-NIO-1] INFO c.t.c.c.c.n.NettyClientConnection - [websocket id: 0-0] Unregistering NettyClientConnection from ClientEndpoint
15:56:00.906 [NettyClient-NIO-1] DEBUG c.t.c.c.e.CommunicationEndpoint - [Endpoint id: 0, connection id: 0-0] removed Connection
15:56:00.908 [NettyClient-NIO-1] INFO c.t.c.c.e.CommunicationEndpoint - All Connections are closed [endpoint id: 0]
15:56:00.909 [NettyClient-NIO-1] INFO c.t.c.client.ConnectedThingClient - Communications Endpoint Closed
15:56:40.917 [Client-EndpointMonitor-1] DEBUG c.t.c.c.e.m.CommunicationEndpointMonitorTask - CommunicationEndpoint Monitor - checking for disconnected endpoints
15:56:40.917 [Client-EndpointMonitor-1] INFO c.t.c.c.e.m.CommunicationEndpointMonitorTask - Endpoint not connected [name: EP_0, id: 0]. Attempting [re]connect...
15:56:40.917 [Client-EndpointMonitor-1] DEBUG c.t.c.c.e.ClientCommunicationEndpoint - Clearing endpoint authentication data [id: 0]
15:56:40.917 [Client-EndpointMonitor-1] INFO c.t.c.c.e.ClientCommunicationEndpoint - Needed to refill connections on client endpoint [id: 0] : [active: 0, max: 1]
15:56:41.052 [NettyClient-NIO-2] DEBUG c.t.c.c.c.n.ThingworxClientConnectionHandler - WebSocket Channel is connected [is open: true]
15:56:41.053 [NettyClient-NIO-2] DEBUG i.n.h.c.h.w.WebSocketClientHandshaker13 - WebSocket version 13 client handshake key: c9E+/s4LcAcBfMLm0DzBiQ==, expected response: RVLPbnBmQzh9YYblHNZGxjyDwzQ=
15:56:41.203 [NettyClient-NIO-2] DEBUG c.t.c.c.c.n.ThingworxClientConnectionHandler - [ClientHandler: 1245348364] Client websocket handshake is complete
15:56:41.204 [Client-EndpointMonitor-1] INFO c.t.c.c.e.ClientCommunicationEndpoint - Preparing new Connection Authentication Request: DispatchingClientEndpoint [id: 0, isConnected: false, open connections: 0, max connections: 1]
15:56:41.204 [Client-EndpointMonitor-1] DEBUG c.t.c.c.e.CommunicationEndpoint - Sending connection authentication message, waiting for response [message: AuthRequestMessage [requestId: 6, endpointId: -1, sessionId: -1, method: AUTHREQUEST]]
15:56:41.205 [NettyClient-NIO-2] DEBUG i.n.h.c.h.w.WebSocket08FrameEncoder - Encoding WebSocket Frame opCode=2 length=60
15:56:41.336 [NettyClient-NIO-2] DEBUG i.n.h.c.h.w.WebSocket08FrameDecoder - Decoding WebSocket Frame opCode=2
15:56:41.336 [NettyClient-NIO-2] DEBUG i.n.h.c.h.w.WebSocket08FrameDecoder - Decoding WebSocket Frame length=17
15:56:41.337 [NettyClient-NIO-2] DEBUG c.t.c.c.e.DispatchingClientEndpoint - RESPONSE received [endpoint id: 0, duration: 133] ResponseMessage [requestId: 6, endpointId: 31, sessionId: 31, code: STATUS_SUCCESS, multipart: false, packet #: 0, total packets: 0]
15:56:41.338 [Client-EndpointMonitor-1] INFO c.t.c.c.e.ClientCommunicationEndpoint - Authentication Request was SUCCESSFUL [tworx session id: 31, connection group id: 31]
15:56:41.339 [Client-EndpointMonitor-1] DEBUG c.t.c.c.e.CommunicationEndpoint - [Endpoint id: 0, connection id: 0-0] added Connection
15:56:41.339 [Client-EndpointMonitor-1] INFO c.t.c.c.e.ClientCommunicationEndpoint - Successfully reconnected client endpoint [id: 0] : [active: 1, max: 1]
15:56:41.341 [Client-EndpointMonitor-1] INFO c.t.c.client.ConnectedThingClient - Communications Endpoint Opened
15:56:41.343 [Client-EndpointMonitor-1] DEBUG c.t.c.c.e.CommunicationEndpoint - Sending synchronous message, waiting for response [message: BindRequestMessage [requestId: 7, method: BINDREQUEST, names: [EP_0, RemoteRollingStock, EP_0]]]
15:56:41.345 [NettyClient-NIO-2] DEBUG i.n.h.c.h.w.WebSocket08FrameEncoder - Encoding WebSocket Frame opCode=2 length=63
15:56:41.480 [NettyClient-NIO-2] DEBUG i.n.h.c.h.w.WebSocket08FrameDecoder - Decoding WebSocket Frame opCode=2
15:56:41.480 [NettyClient-NIO-2] DEBUG i.n.h.c.h.w.WebSocket08FrameDecoder - Decoding WebSocket Frame length=17
15:56:41.482 [NettyClient-NIO-2] DEBUG c.t.c.c.e.DispatchingClientEndpoint - RESPONSE received [endpoint id: 0, duration: 139] ResponseMessage [requestId: 7, endpointId: -1, sessionId: -1, code: STATUS_SUCCESS, multipart: false, packet #: 0, total packets: 0]
15:56:41.482 [Client-EndpointMonitor-1] INFO c.t.c.c.e.m.CommunicationEndpointMonitorTask - Endpoint reconnected [name: EP_0, id: 0]
15:56:41.669 [ClientProcessor-1] WARN c.t.c.client.things.VirtualThing - Unable to get property subscriptions. Timed out APIRequestMessage [requestId: 3, endpointId: 0, sessionId: 30, method: POST, entityName: EP_0, characteristic: Services, target: GetPropertySubscriptions]
15:56:41.669 [ClientProcessor-1] DEBUG c.t.c.c.e.CommunicationEndpoint - Sending synchronous message, waiting for response [message: APIRequestMessage [requestId: 8, endpointId: 0, sessionId: 31, method: POST, entityName: EP_0, characteristic: Services, target: GetEventSubscriptions]]
15:56:41.671 [NettyClient-NIO-2] DEBUG i.n.h.c.h.w.WebSocket08FrameEncoder - Encoding WebSocket Frame opCode=2 length=46
15:56:41.673 [ClientProcessor-2] WARN c.t.c.client.things.VirtualThing - Unable to get property subscriptions. Timed out APIRequestMessage [requestId: 4, endpointId: 0, sessionId: 30, method: POST, entityName: EP_0, characteristic: Services, target: GetPropertySubscriptions]
15:56:41.674 [ClientProcessor-2] DEBUG c.t.c.c.e.CommunicationEndpoint - Sending synchronous message, waiting for response [message: APIRequestMessage [requestId: 9, endpointId: 0, sessionId: 31, method: POST, entityName: EP_0, characteristic: Services, target: GetEventSubscriptions]]
15:56:41.676 [NettyClient-NIO-2] DEBUG i.n.h.c.h.w.WebSocket08FrameEncoder - Encoding WebSocket Frame opCode=2 length=46
15:56:41.678 [ClientProcessor-3] WARN c.t.c.client.things.VirtualThing - Unable to get property subscriptions. Timed out APIRequestMessage [requestId: 5, endpointId: 0, sessionId: 30, method: POST, entityName: RemoteRollingStock, characteristic: Services, target: GetPropertySubscriptions]
15:56:41.679 [ClientProcessor-3] DEBUG c.t.c.c.e.CommunicationEndpoint - Sending synchronous message, waiting for response [message: APIRequestMessage [requestId: 10, endpointId: 0, sessionId: 31, method: POST, entityName: RemoteRollingStock, characteristic: Services, target: GetEventSubscriptions]]
15:56:41.681 [NettyClient-NIO-2] DEBUG i.n.h.c.h.w.WebSocket08FrameEncoder - Encoding WebSocket Frame opCode=2 length=60
15:56:41.797 [NettyClient-NIO-2] DEBUG i.n.h.c.h.w.WebSocket08FrameDecoder - Decoding WebSocket Frame opCode=2
15:56:41.798 [NettyClient-NIO-2] DEBUG i.n.h.c.h.w.WebSocket08FrameDecoder - Decoding WebSocket Frame length=63
15:56:41.800 [NettyClient-NIO-2] DEBUG c.t.c.c.e.DispatchingClientEndpoint - RESPONSE received [endpoint id: 0, duration: 131] ResponseMessage [requestId: 8, endpointId: 0, sessionId: -1, code: STATUS_SUCCESS, multipart: false, packet #: 0, total packets: 0]
15:56:41.807 [NettyClient-NIO-2] DEBUG i.n.h.c.h.w.WebSocket08FrameEncoder - Encoding WebSocket Frame opCode=2 length=17
15:56:41.809 [NettyClient-NIO-2] DEBUG i.n.h.c.h.w.WebSocket08FrameDecoder - Decoding WebSocket Frame opCode=2
15:56:41.812 [NettyClient-NIO-2] DEBUG i.n.h.c.h.w.WebSocket08FrameDecoder - Decoding WebSocket Frame length=63
15:56:41.813 [NettyClient-NIO-2] DEBUG c.t.c.c.e.DispatchingClientEndpoint - RESPONSE received [endpoint id: 0, duration: 138] ResponseMessage [requestId: 9, endpointId: 0, sessionId: -1, code: STATUS_SUCCESS, multipart: false, packet #: 0, total packets: 0]
15:56:41.814 [NettyClient-NIO-2] DEBUG i.n.h.c.h.w.WebSocket08FrameEncoder - Encoding WebSocket Frame opCode=2 length=17
15:56:41.819 [NettyClient-NIO-2] DEBUG i.n.h.c.h.w.WebSocket08FrameDecoder - Decoding WebSocket Frame opCode=2
15:56:41.821 [NettyClient-NIO-2] DEBUG i.n.h.c.h.w.WebSocket08FrameDecoder - Decoding WebSocket Frame length=63
15:56:41.822 [NettyClient-NIO-2] DEBUG i.n.h.c.h.w.WebSocket08FrameDecoder - Decoding WebSocket Frame opCode=8
15:56:41.823 [NettyClient-NIO-2] DEBUG c.t.c.c.e.DispatchingClientEndpoint - RESPONSE received [endpoint id: 0, duration: 144] ResponseMessage [requestId: 10, endpointId: 0, sessionId: -1, code: STATUS_SUCCESS, multipart: false, packet #: 0, total packets: 0]
15:56:41.827 [NettyClient-NIO-2] INFO c.t.c.c.c.n.NettyClientConnection - [websocket id: 0-0] Closing underlying websocket channel
15:56:41.829 [NettyClient-NIO-2] INFO c.t.c.c.c.n.NettyClientConnection - [websocket id: 0-0] Unregistering NettyClientConnection from ClientEndpoint
15:56:41.830 [NettyClient-NIO-2] DEBUG c.t.c.c.e.CommunicationEndpoint - [Endpoint id: 0, connection id: 0-0] removed Connection
15:56:41.834 [NettyClient-NIO-2] INFO c.t.c.c.e.CommunicationEndpoint - All Connections are closed [endpoint id: 0]
15:56:41.835 [NettyClient-NIO-2] INFO c.t.c.client.ConnectedThingClient - Communications Endpoint Closed
15:56:41.837 [NettyClient-NIO-2] DEBUG i.n.h.c.h.w.WebSocket08FrameEncoder - Encoding WebSocket Frame opCode=2 length=17
Bob, is the clientConfiguration configured to attempt connections every n number of seconds/minutes? Could share your code or pseudo code how the property is being updated?
If it helps, here's the sample code to initiate the connection and keep attempting it every few seconds i used in one of my project :
public class ClinetConfigurator {
private static final Logger LOG = LoggerFactory.getLogger(ClientConfigurator.class);
public static Random random = new Random();
public static void main(String[] args) {
try {
// Setting the server URL and the appkey to enable this client to
// connect to the ThingWorx platform
//Applicaton server on TWX70
String serverURL = "<serverAddress>/WS";
String appKey = "<appKey>";
// configure client
ClientConfigurator config = new ClientConfigurator();
config.setUri(serverURL);
config.setAppKey(appKey);
config.getSecurityClaims().addClaim(appKey, appKey);
// connected to client
ConnectedThingClient client = new ConnectedThingClient(config, null);
// start the client
client.start(); // Async - doesn't always mean that the client has
// started immediately when the method is called
//create and bind the virtual thing to the platform
TractorVirtualThing tractorThing = new TractorVirtualThing("GreenCo.Tractor1", "A virtual thing", client);
LOG.debug("Binding to " + serverURL + "to register thing" + tractorThing.getName());
// binding happens just once with 1 connection
client.bindThing(tractorThing);
LOG.debug("Connecting to " + serverURL + "using key" + appKey);
while (true) {
if(client.getEndpoint().isConnected()) {
tractorThing.processScanRequest();
Thread.sleep(random.nextInt(300));
Thread.sleep(6000); // cycle every miliseconds
} catch (Exception e) {
// Catching the exception in case the connection or the binding fails
LOG.error("An error occured", e);
e.printStackTrace();
Hi Sushant,
Thanks for sharing the above code. But this did not helped me. I am still facing the same issue.
Hi Sushant,
There was one mistake in my code. I was not setting uri of actual thingworx core rather it was by default pointing to local. I made the changes as below
this.config = new ClientConfigurator();
this.config.setUri("ws://13.113.122.50:80/Thingworx/WS");
But after this I am getting another error. Please have a look at trace below.
18:57:21.478 [main] DEBUG c.t.c.c.e.m.CommunicationEndpointMonitorTask - Initializing CommunicationEndpoint Connection Monitor...
18:57:21.479 [Client-EndpointMonitor-1] DEBUG c.t.c.c.e.m.CommunicationEndpointMonitorTask - CommunicationEndpoint Monitor - checking for disconnected endpoints
18:57:21.479 [Client-EndpointMonitor-1] INFO c.t.c.c.e.m.CommunicationEndpointMonitorTask - Endpoint not connected [name: EP_0, id: 0]. Attempting [re]connect...
18:57:21.479 [Client-EndpointMonitor-1] DEBUG c.t.c.c.e.ClientCommunicationEndpoint - Clearing endpoint authentication data [id: 0]
18:57:21.479 [Client-EndpointMonitor-1] INFO c.t.c.c.e.ClientCommunicationEndpoint - Needed to refill connections on client endpoint [id: 0] : [active: 0, max: 1]
18:57:21.505 [Client-EndpointMonitor-1] DEBUG i.n.util.internal.ThreadLocalRandom - -Dio.netty.initialSeedUniquifier: 0xa0d91cd57cf054e5 (took 2 ms)
18:57:21.535 [Client-EndpointMonitor-1] DEBUG io.netty.buffer.ByteBufUtil - -Dio.netty.allocator.type: unpooled
18:57:21.535 [Client-EndpointMonitor-1] DEBUG io.netty.buffer.ByteBufUtil - -Dio.netty.threadLocalDirectBufferSize: 65536
18:57:21.598 [NettyClient-NIO-1] DEBUG io.netty.util.ResourceLeakDetector - -Dio.netty.leakDetectionLevel: simple
18:57:31.553 [Client-EndpointMonitor-1] INFO c.t.c.c.c.n.NettyClientConnectionFactory - forcing underlying tcp channel closed [is open: true, is active: false]
18:57:31.554 [Client-EndpointMonitor-1] ERROR c.t.c.c.e.ClientCommunicationEndpoint - Refilling connections on [endpoint 0, uri: ws://13.113.122.50:80/Thingworx/WS] failed : timeout waiting for websocket handshake to complete
18:57:31.554 [Client-EndpointMonitor-1] INFO c.t.c.c.e.m.CommunicationEndpointMonitorTask - Endpoint reconnection was unsuccessful [name: EP_0, id: 0]
Any idea?
Is the server already reachable for you? because I can't get to the authentication page for your server's IP. So you might want to hold on till the IP is reachable again and secondly I can't see that your server instance is defining port 80 so you test removing that once the server is responding again.
bob argo,
Just to add if it's secured connection; in uri it would be wss instead of ws.
Hi Sushant,
Below is the code for client and Virtual Thing
Client.
public class RollingStockClient extends ConnectedThingClient {
private static final Logger LOG = LoggerFactory.getLogger(RollingStockClient.class);
public RollingStockClient(ClientConfigurator config) throws Exception {
super(config);
// TODO Auto-generated constructor stub
throws Exception
MasterClientConfigurator masterconfig = new MasterClientConfigurator(args);
int scanRate = 30000;
RollingStockClient client = new RollingStockClient(masterconfig.config);
RollingStockThing rollingStockThing = new RollingStockThing("RemoteRollingStock", "RollingStock", client);
client.bindThing(rollingStockThing);
try
System.out.println(masterconfig);
client.start();
catch (Exception eStart)
System.out.println("Initial Start Failed : " + eStart.getMessage());
while (!client.isShutdown())
if (client.getEndpoint().isConnected()) {
for (VirtualThing thing : client.getThings().values()) {
try
thing.processScanRequest();
catch (Exception eProcessing)
System.out.println("Error Processing Scan Request for [" + thing.getName() + "] : " + eProcessing.getMessage());
Thread.sleep(scanRate);
Vitual Thing
@ThingworxPropertyDefinitions(properties={@com.thingworx.metadata.annotations.ThingworxPropertyDefinition(name="Prop_TempSetPoint1", description="TempSetPoint of vending machine 1", baseType="NUMBER", aspects={"dataChangeType:NEVER", "dataChangeThreshold:0", "cacheTime:-1", "isPersistent:true", "isReadOnly:false", "pushType:NEVER", "defaultValue:35.34"}), @com.thingworx.metadata.annotations.ThingworxPropertyDefinition(name="Prop_TempSetPoint2", description="TempSetPoint of vending machine 2", baseType="NUMBER", aspects={"dataChangeType:NEVER", "dataChangeThreshold:0", "cacheTime:-1", "isPersistent:true", "isReadOnly:false", "pushType:NEVER", "defaultValue:35.78"}), @com.thingworx.metadata.annotations.ThingworxPropertyDefinition(name="Prop_HumSetPoint1", description="HumSetPoint of vending machine 1", baseType="NUMBER", aspects={"dataChangeType:NEVER", "dataChangeThreshold:0", "cacheTime:-1", "isPersistent:true", "isReadOnly:false", "pushType:NEVER", "defaultValue:70.23"}), @com.thingworx.metadata.annotations.ThingworxPropertyDefinition(name="Prop_HumSetPoint2", description="HumSetPoint of vending machine 2", baseType="NUMBER", aspects={"dataChangeType:NEVER", "dataChangeThreshold:0", "cacheTime:-1", "isPersistent:true", "isReadOnly:false", "pushType:NEVER", "defaultValue:70.93"}), @com.thingworx.metadata.annotations.ThingworxPropertyDefinition(name="Prop_Equipment1Temp", description="Current temperature of vending machine 1", baseType="NUMBER", aspects={"dataChangeType:ALWAYS", "dataChangeThreshold:0", "cacheTime:0", "isPersistent:FALSE", "isReadOnly:TRUE", "pushType:VALUE", "defaultValue:0"}), @com.thingworx.metadata.annotations.ThingworxPropertyDefinition(name="Prop_Equipment2Temp", description="Current temperature of vending machine 2", baseType="NUMBER", aspects={"dataChangeType:ALWAYS", "dataChangeThreshold:0", "cacheTime:0", "isPersistent:FALSE", "isReadOnly:TRUE", "pushType:VALUE", "defaultValue:0"}), @com.thingworx.metadata.annotations.ThingworxPropertyDefinition(name="Prop_Equipment1Hum", description="Current humidity of vending machine 1", baseType="NUMBER", aspects={"dataChangeType:ALWAYS", "dataChangeThreshold:0", "cacheTime:0", "isPersistent:FALSE", "isReadOnly:TRUE", "pushType:VALUE", "defaultValue:0"}), @com.thingworx.metadata.annotations.ThingworxPropertyDefinition(name="Prop_Equipment2Hum", description="Current humidity of vending machine 2", baseType="NUMBER", aspects={"dataChangeType:ALWAYS", "dataChangeThreshold:0", "cacheTime:0", "isPersistent:FALSE", "isReadOnly:TRUE", "pushType:VALUE", "defaultValue:0"})})
public class RollingStockThing extends VirtualThing {
private static final long serialVersionUID = -3419672881497640537L;
Random randomGenerator;
boolean ranScanOnce = false;
public RollingStockThing(String name, String description, ConnectedThingClient client)
super(name, description, client);
initializeFromAnnotations();
this.randomGenerator = new Random();
try
setProperty("Prop_TempSetPoint1", getProperty("Prop_TempSetPoint1").getPropertyDefinition().getDefaultValue().getValue());
setProperty("Prop_TempSetPoint2", getProperty("Prop_TempSetPoint2").getPropertyDefinition().getDefaultValue().getValue());
setProperty("Prop_HumSetPoint1", getProperty("Prop_HumSetPoint1").getPropertyDefinition().getDefaultValue().getValue());
setProperty("Prop_HumSetPoint2", getProperty("Prop_HumSetPoint2").getPropertyDefinition().getDefaultValue().getValue());
catch (Exception localException) {}
public void processScanRequest()
throws Exception
super.processScanRequest();
scanDevice();
public void scanDevice()
throws Exception
setProperty("Prop_Equipment1Temp", Double.valueOf(getRandomOscillation(((Double)getProperty("Prop_Equipment1Temp").getValue().getValue()).doubleValue(), ((Double)getProperty("Prop_TempSetPoint1").getValue().getValue()).doubleValue())));
setProperty("Prop_Equipment2Temp", Double.valueOf(getRandomOscillation(((Double)getProperty("Prop_Equipment2Temp").getValue().getValue()).doubleValue(), ((Double)getProperty("Prop_TempSetPoint2").getValue().getValue()).doubleValue())));
setProperty("Prop_Equipment1Hum", Double.valueOf(getRandomOscillation(((Double)getProperty("Prop_Equipment1Hum").getValue().getValue()).doubleValue(), ((Double)getProperty("Prop_HumSetPoint1").getValue().getValue()).doubleValue())));
setProperty("Prop_Equipment2Hum", Double.valueOf(getRandomOscillation(((Double)getProperty("Prop_Equipment2Hum").getValue().getValue()).doubleValue(), ((Double)getProperty("Prop_HumSetPoint2").getValue().getValue()).doubleValue())));
this.ranScanOnce = true;
Thread.sleep(1500);
updateSubscribedProperties(10000);
private double getRandomOscillation(double currentValue, double setPoint)
if (!this.ranScanOnce) {
currentValue = setPoint;
double offset = 0.0D;
if ((Math.abs(currentValue - setPoint) > 3.0D) && (currentValue < setPoint)) {
offset = this.randomGenerator.nextDouble() * 500.0D / 100.0D;
} else if ((Math.abs(currentValue - setPoint) > 3.0D) && (currentValue > setPoint)) {
offset = -(this.randomGenerator.nextDouble() * 500.0D / 100.0D);
} else if (Math.abs(currentValue - setPoint) <= 3.0D)
if (currentValue <= setPoint) {
offset = this.randomGenerator.nextDouble() * 200.0D / 100.0D;
} else if (currentValue > setPoint) {
offset = -(this.randomGenerator.nextDouble() * 200.0D / 100.0D);
else {
offset = this.randomGenerator.nextDouble();
return currentValue + offset;
