I've installed thingworx extension in eclipse but I'm unable to see in prespectives.
@SaiSameera Ensure in eclipse that the extension got installed successfully by checking installed software history. Go to Install New software -> click What is already installed link and confirm ThingWorx Extension Builder is listed under Installed Software.
If extension is installed, then you should see ThingWorx Extension in Perspective. PFA for more details.
Hope it helps.
-Durgesh
Hope it helps.
-Durgesh
Hi dupatel,
The extension has installed successfully. But I'm unable to view in presepective. PFA for details
Thanks for your response. I'm able to see now in perspective. The reason is I've installed different eclipse version.
