Unable to select the Property in Subscription
dm-21
How could it be possible to select a property without selecting the source in the Subscription? for me its not working, i can't able to add the required property without selecting the source.property.gif
vmihai
(To:dm-21)
Hi Dhivya,
Have you created an Alert on the Temperature property ? This step is covered in on page  2 in this tutorial for Weather App with Arduino Uno : http://www.thingworx.com/-/media/Files/PDFs/Academics/33AUHowtoCreateaMashupforArduinoUnoStep3.pdf?la=en
Please create first this alert as instructed in the tutorial and then the subscription on the Temperature property.
Let me know if this fixes the issue.
Thank you,
Veronica
dm-21
(To:vmihai)
Sorry Veronica, that was my mistake instead of searching the subscription's property in HTU21DThing, i was searching that in WeatherNotifier subscription property. now i cleared the issue.
Thank you,
Dhivya
PaiChung
22-Sapphire I
(To:dm-21)
By not setting a Source, it exposes Properties, Alerts and Events that are part of the Entity itself.
For a property you can either go with DataChange events for a Property (select DataChange/AnyDataChange) or Alerts (select Alert/AnyAlert)
dm-21
(To:PaiChung)
Hi Sir,
Sorry sir, that was my mistake instead of searching the subscription's property in HTU21DThing, i was searching that in WeatherNotifier subscription property. now i cleared the issue.
Thanks a lot for your guidance sir.
Thank you,
Dhivya
