Hi ,
I'm unable to send SMS using twilio extension, getting java socket exception.
The same extension is working in another server which has similar configuration.
Both servers running on SSL. Do I have to change any specific configuration?
please find the error attached.
Janakiraman P
Hi Janakraman,
If both servers configuration is similar and one is working fine, it's likely having issue on network or OS side.
Did you check Firewall and Proxy setting?
Hi @kazunari
Thanks for your responds.
The above issue has been resolved in Thingworx version 8.5.14. Not sure that issue related to the version.
Janakiraman P
