Greetings - I'm a university researcher working with a local startup company developing an environmental monitoring solution for indoor air quality monitoring and HVAC control. The architectural model is straightforward: many sensing endpoints, all using low power, sub-GHz radios, communicating to WiFi-connected base stations. Some base stations are equipped with cellular to support fail-over. We're helping them evaluate a couple of different IoT platforms. The current plan is to use
Raspberry-Pi-based base stations for connectivity, but I wanted to reach out to see if you have a base station recommendation that would streamline things. Any getting started tips would also be appreciated -- though we will read the documentation!
Hi William,
Have you considered browsing the video's section here in the Developer Community for possible related content:
There are also a few blog posts on using Raspberry Pi: https://community.thingworx.com/community/developers/content?filterID=contentstatus%5Bpublished%5D~objecttype~objecttype%5Bblogpost%5D
This specific blog post has several TWX Video Tutorials in one spot:
Hope this helps. If you are looking for more specific guidance, please respond back.
Steve
Thanks, Steve, I'll definitely take a look at these.
Have a great weekend!
William
