I have much data to show to the user in repeater so I am unchecking the property HideInnerScrollbars of Repeater widget. When I load the page repeater showing the vertical scroll bar that I was expected.
But when I just click on repeater anywhere I am getting Horizontal scroll bar And repeater widget is shaking. How to avoid this unwanted behavior ?
Siva
Raju, by getting a scroll bar, does it show up when you select a row in the Repeater? And can you expand on the shaking part? Are the scroll bars going back and forth?
Yes, When I select row.. Horizontal scrollbar coming.
And you understood correct on shaking part.
What version of ThingWorx and what browser are you trying it on? Can you try a different browser? The repeater is on a panel, correct?
Hi Siva,
I've never used that property, but still without using it you will have a hard time ( if you have a complex repeater/mashup ) to get ride of Scrollbars at all, I thrown the towel a long ago about it I can't be on help here, and I think it's not possible to get rid of it all ( at the same time, you may think that you got ride of it on one browser, to then realize that on another browser they appear ).
Best Luck,
Carles.
