I need feature to work on mobile phone for uploading images in File Repository, however, I want to replace the file upload widget with a single button to choose the image.
For example:
Instead of showing this:
Show something like this:
When I click the button marked as red I can choose te image that will replace the grey area.
The reason why I want to do this is because the File Upload widget is a little big and I can't set any style.
If there's any other file upload widget, please, recommend me.
Thanks in advance.
Radix Engineering and Software: Unfortunately, I believe we do not have any other standard widget similar to this at this point however suggest you to further check out ThingWorx Marketplace for existing tools & solutions. Other option would be to develop custom widget as per your requirement and use case.
-Durgesh
