Upon session time out need to redirect to login page
SKannapiran
In ThingWorx, I have set the session timeout to 15 minutes. After the session times out, the expectation is that ThingWorx will redirect to the login page. Alternatively, a pop-up should appear with the message "Session timed out. Please log in to continue" and an OK button. Clicking the OK button should then redirect to the login page.
Is there a way to implement this functionality? Please provide the code or implementation steps.
Rocko
(To:SKannapiran)
Have you already read the various articles in the community about this? None of those worked for you?
https://community.ptc.com/t5/ThingWorx-Developers/Redirect-login-to-FormLogin/m-p/506704
Hi @SKannapiran,
I wanted to follow up with you on your post to see if your question has been answered.
If so, please mark the appropriate reply as the Accepted Solution.
Of course, if you have more to share on your issue, please let the Community know so that we can continue to help you.
Anurag
