We have a client's requirement that a user's login should work when they do a finger print scan from a scanner.
I have some ideas and need some assistance on how to achieve it on thingworx.
My question is,
Sri1
Hi Sri1,
I would never store bio-metric user data in the Thing Model - that information is highly private and really required only for the login phase. The Thing Model should be only used for the application usecase needs.
You should search and see if there is an identity provider that supports bio-metric authentication and use Ping Federate to integrate with that.
I believe Okta has some articles which might give you the correct direction, albeit not really good.
Regardless, keep in mind that really you should not use ThingWorx to manage the biometric data, and instead use a third-party tool that does that for you.
Hi @Sri1.
If you feel the previous response was helpful, please mark it as the Accepted Solution for the benefit of others in the community.
--Sharon
