Hi!
Currently I'm using "Relational DB Connectors Extension" to connect external DB from Thingworx Server, which supports DB2/MSSQL/MYSQL/Oracle/PostgreSQL.
Now my project needs to connect to a MS Access DB, from Server, not from Edge.
Is that possible?
How to do so?
Thanks.
Hi @tallrain , Please follow the linkhttps://community.ptc.com/t5/ThingWorx-Developers/Access-Microsoft-Access-db-from-Thingworx/td-p/513785
Hi @tallrain.
If you feel your question has been answered, please mark the previous response as the Accepted Solution for the benefit of others in the community.
Regards.
--Sharon
