Hello everyone,
i want to use the collection widget for showing the same mashup with the same service but different service parameters.
I did this tutorial here:
https://developer.thingworx.com/en/resources/guides/collection-widget-how-to/create-thing-cwht
But here it is using the service once and saves the results in to a infotable where each row and the corresponding columns represent one mashup in the collection widget.
I am not saving the data to the infotable.
I want to show timeseries data to which will not be possible if the data is only provided by an infotable. I am using multiple ones. One for timeseries data and one for some statistics.
you can merge the timeseries data with the statics infotable into same infotable property, and feed into the widget
