Hi everyone,
I am currently working in developing some IoT demos by connecting TI SensorTags (it contains 10 different kinds of sensors) to ThingWorx. I have already installed the MQTT broker (Mosquitto) and imported the MQTT extension on TW.
In order to model my SensorTag as a Thing, based on the imported MQTT ThingTemplate, and then represent all the properties on mashup, I would need to figure out all the specific steps required to correctly configure and validate the connection between the broker and mobile app.
I would appreciate any reference guide or detailed description related to my issue.
Thank you in advance,
Ivan
Hi Ivan Lopez,
Please refer to the following articles:
https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS246701&lang=en_US
https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS205221&lang=en_US
Hi Ankit,
Thanks for your hints: I have been able to configure the TW platform with the Mosquitto server on my laptop.
However, I am currently facing some communication issues as described below:
The facing issue relates to the fact that these two sides do not "speak" each other: sending some values from the MQTT Client mobile app to the Mosquitto server, they are not received by the TW platform. So, I am not able to figure if there is some connection configuration trouble.
Below the printscreen of the TW Log.
Ivan
I have made a new trial and I guess the issue is the following:
"Error Handling Publish Arrived for [random/temp] : [Unable To Convert From java.lang.String to NUMBER]"
Could someone suggest me how to convert the input string-value, coming from the broker, into a number on the related mashup?
Appreciating your help,
Ivan
Could you please show your service with input values/its types? Perhaps you could create an intermediate service that would extract the numbers from the string, possibly via json
Hi Polina,
I have not created the service yet, that is my concern. I am trying to understand which TW entities should I model in order to define this service.
What I am doing is the following: I am sending some number inputs from the MQTT Client mobile app to MQTT Mosquitto Broker on my laptop (this corrently works) but I am not able to report the sent data on TW dashboard.
On the Thingworx side: the MQTT broker correctly works with Thingworx just putting some values from mosquitto command line: the value are correctly updatedon my mashup.
At this aim, looking at the previous posted error, I am trying to understand if the problem could be just a matter of conversion from string input to number output. The configured topic is "random/temp" as shown below. I hope this helps.
Thank you,
Ivan
Dear Ivan,
Have you managed to make it work?
Cheers, Christian
