How TW Analytics could be used for finding dependancies / correleations between fields in a dataset.
I.e. for the dataset on the screenshot below I would expect to get insights like
If x2=3 then x1 is guaranteed to be 7
If x5=3 and x4!=2 then x1 is rather likely (80%) to be 8
If x1=6 then x3 is most likely (~85%) to be 7
and so on
The first approach that came to my mind is that this is basically a categorical (ordinal?) data, but currently handling it in TWA is only possible using custom code / mashups etc
So then I thought about adding another boolean column, say, 'target' and set it to '1' for a given value of a field (say, for x1=8) and then dropping the x1 field from the dataset.
This kind of works, but requires a bit of overhead activities.
Do I understand the things right?
Am I missing some other approaches?
Hi Dmitry,
I am following up on this post and wanted to let you know that a feature request (JIRA TA-2595) has been opened requesting Signals and Profiles jobs to handle Categorical and Ordinal Goals.
John
Just wanted to clarify a bit...
When using "dataType": "INTEGER", "opType": "CONTINUOUS" the model Analytics builds seem to be correct. And I can even run predictive scoring against the model (seem to work correct).
The problem is that Profiles and Signals don't show the expected insights.
On the Signals screenshot below (goal set to x1 when building the model) Analytics rates x3 field with value of 22 very low, but actually x3=22 gives 100% chance that x1=1
Not to mention that x3 doesn't even appear in Profiles (because of that MaximizeGoal true/false parameter).
Should I really handle this with opType=categorical?
Or it should work with Integer and I just missunderstand some vital concept?
I have reached out to our (PTC) Dev team regarding your questions below and will get back to you when I hear back from them.
Please let me know if you have any other questions or concerns in the meantime.
Warm Regards,
John
Hi John
Thanks for the response. I've actually gave up on the issue and settled down for waiting the release which supports categorical type of goals to validate my assumptions.
So far I concluded that the currently implemented analytics with integer goal are suited for the cases like "how to maximize the amount of goods produced daily" (where goal would be the Integer value reflecting amount of produced goods) or "how to minimize the amount of defective goods" (goal - Integer value reflecting amount of defective goods).
And in my case I really don't want to maximize or minimize the goal, I just need to find correlation between particular values of the goal and other fields. So now it looks to me that for such kind of problems, indeed the categorical type of goal is the way to go.
Best regards,
Dmitry
Hi Dmitry,
John
Thank you for the update, John, much appreciated.
