Using Thingworx to push data to Power BI via Power BI Rest API
SOLVED
Highlighted
Granite
Hello together,
I want to push data from thingworx to PowerBIs Rest API.
Someone have experience with this topic and can help with a sollution?
Please dont write "what is possible". I can google myself .
I need someone who finished this task.
1 ACCEPTED SOLUTION
Highlighted
Re: Using Thingworx to push data to Power BI via Power BI Rest API
Yes, the authentification is the issue.
I have finished this
6 REPLIES 6
Highlighted
Hi @bot1q.
We would recommend reviewing the services available in the ContentLoaderFunctions resource.  It has several services available out of the box that allow you to interact with RESTful applications from the ThingWorx platform.
--Sharon
Highlighted
Thanks ... but that ist Not the question... I now how to send get/Post etc. This ist specific question to Power bei running on azure
Highlighted
There is documentation in https://docs.microsoft.com/en-us/rest/api/power-bi/pushdatasets
And of course, you could have Googled this too, I know.
It would be good to know what exactly you are looking for, since the api is freely viewable.
The problem here is always authentication. User/password is normally not allowed.
I haven't tried with Power BI api, but in the past I tried to connect to Microsoft Sharepoint, and that wasn't easy, and we didn't go further with it.
Highlighted
Hi, did you succeed in doing it, or did you finish investigating?
If you succeeded, can you share your thoughts, conclusion or solution?
Highlighted
Hi @bot1q.
If one of the previous responses answered your question, please mark the appropriate one as the Accepted Solution for the benefit of others with the same question.  If you still have unanswered questions, please let us know.
--Sharon
Thingworx Navigate content has a new home! Click here to access the new Thingworx Navigate forum!
