I'm trying to reference a file in the FileRepository and it worked fine but adds this:
&__rnd=0.8384068009909242
I referenced it as: ../../Thingworx/MediaEntities/noUserImage
and the result is: http://192.168.0.99:8080/Thingworx/MediaEntities/noUserImage&__rnd=0.8384068009909242
All is good but the end parameters.
Hi Martin,
That "trash" is a feature! By appending it to the URL, we ensure the browser will not cache the image and the end user will see the latest version of the Media Entity. If you prefer a cleaner URL, you can uncheck the PreventCaching property of the Image widget.
Adam
Helo Adam:
Thanks, somehow if you use the prevent caching property in the image widget and set the url source on the fly it may or not work.
Thank you.
