Hi Community,
I have two text filed area widgets for phone no. and email id and have set validators to check they are not null.Now I also want to check both the text boxes separately if the phone no. and email entered are valid.What is the code I need to give in the validators if my parateres are PhoneNo. and Email.
Hello Alena,
See Using a Validator with a Service to perform more advanced analytics which makes use of a backing service to accomplish verification of these fields. In addition to this you may be able to use the Validator's expression field with Reg Ex directly but I have not tested this. There is an example of this operation in CS233996 for the Expression widget.
Hello Alena,
