Hi community,
I want to set a specific validation for input text boxes in about 4-5 mashups of mine.Is there anyway I can reuse the validator I use a particular mashup with the rest of the mashups.If not can I bind services to the validator function so i can reuse it in all mashups instead of creating validators for every mashup.
Hi @alenaromi
One idea could be to use the validator in a master mashup and add this master in the desired mashup.
Maybe others have better ideas.
Christophe
Hi @alenaromi
Christophe
Hi @alenaromi.
If the previous response allowed you to find a solution, please mark it as the Accepted Solution for the benefit of others on the community. If you have found a different solution, please post a reply to share it with the rest of the community.
Regards.
--Sharon
