Hi guys,
I want to display an image in the widget value display. Aparrently it's easy but impossible to find a correct way to do it. I add a property image in my thing where I put an image. Now I suppose I have to grab it in my mashup but I don't know how.
Can you help me ?
Guillaume
I agree with Nidhi.
You can also use the inbuilt service GetPropertyValues of the Thing where you have added the Image property.
Set the Mashup Loaded option as checked while adding this service.
Now just link your property from All Data of GetPropertyValues service and link it to the value display widget -> Data.
I hope it helps.
Ankit Gupta
You simply need to map the output of image property to the 'Data' input field of the Display Value widget. You can create a service for getting properties of the ThingTemplate/Thing and then do the required mapping as stated.
Nidhi Bansal
I agree with Nidhi.
I hope it helps.
Ankit Gupta
