ValueStream and location property
LaurentGermain
6-Contributor
On my thing, associated to a ValueStream, the "location"  property is logged , and with change type set to either  Always or value, the values are neverlogged.
When doing a QueryPropertyHistory, the colomn location is empty.
Anyone met that issue  or have an idea to fix it ?
How is the location value being changed? And if you manually set the location does it record it in the stream?
The value is being changed by a calaculated expression triggered by an AutoRefresh widget.
Seems to be a big with the standard "location" property;
i created another property called position, and this is is being recorded in the stream....
I have the same issue.  My property named "location" won't record to the stream, but named "myLocation" it works correctly.  Is this expected? Is there anyway for the "location" property to record to the valuestream?
qn
(To:davidcor)
Maybe it's because frequently there's already a "location" field of ThingWorx's data, I guess. And their "location" has a special structure.
