Viewing a PDF file stored in a network share
OCMutz
In a PoC I'm faced with following Use Case:
For a internal application I need to view PDF files which are stored on a network share.
It is possible to open the file in a browser window by entering something like:
file://///servername/share/Loremipsum.pdf
When using this as the URL for a Webframe widget, the widget won't display anything. Even a Link will not open a new window.
There are no entries in the application.log.
Any ideas how to get access to a locally stored PDF and present that to the user?
What will be the best architecture for this?
OCMutz
(To:cbuse)
thanks for the Information, but copying all the files to the Thingworx repository would create a set of redundant data, which would be not acceptable in the PoC.
Finally I created a context in the Thingworx Tomcat that is redirected to the Network share. This is working quite well.
cbuse
(To:OCMutz)
Place the pdf into a ThingWorx file repository. Then, the input "URL" for the web frame widget would look like this: http://<host:port>/Thingworx/FileRepositoryDownloader?download-repository=<YourThingWorxRepository>&directRender=true&download-path=/your_pdf.pdf
OCMutz
(To:cbuse)
