Visual SDK - Gulp Error
AlessandroN
Hi, I'm trying to build a widget using the Visual SDK on Thingworx 9.
I've already downloaded the required packages from the PTC Software Download page:
  • MED-61347-CD-090_F000_WEB-Component-SDK-Utility.zip
  • ThingWorx_Web_Component_Widget.zip
In the official tutorial the steps are 4:
  1. Open a command prompt, then change the current directory to the location on your system where you extracted the SDK utility:
    cd twx-wc-sdk-utility
  2. Run the following command to install the utility:
    npm link
  3. Change your directory to the simple-el-widget/ folder that you created earlier (previously downloaded and unzipped
    cd simple-el-widget
  4. In the widget folder, run the following command to create the extension:
    mub
An extension ZIP file is created and placed in the dist/ folder of your working directory. You are now ready to import the extension.
But the mub command gives me back this error:
Starting series of gulp tasks for the wrapping...
exec error: Error: Command failed: gulp --e --wd C:\CDM\GitLab Cloud\libraries\thingworx\thingworx-web-component-library\simple-el-widget
[10:12:30] Task never defined: Cloud\libraries\thingworx\thingworx-web-component-library\simple-el-widget
[10:12:30] To list available tasks, try running: gulp --tasks
Seems that in the widget folder the gold task file is missing.
There is anyone who already faced this error?
thanks,
Alessandro
Hi @AlessandroN ,
Looking at the error message, it might be because of the space in the folder name:
Can you rename the "GitLab Cloud" folder to something else? Like "GitLabCloud" and try again.
6 REPLIES 6
slangley
(To:AlessandroN)
Hi @AlessandroN.
Is this the tutorial you're using?
--Sharon
Hi @slangley ,
yes it is
slangley
(To:AlessandroN)
Hi @AlessandroN.
I see that you have another post on this topic which already has an accepted solution.  Please confirm that you still need assistance on this one.
--Sharon
It's another topic, this one refers to a different issue.
Please read the content.
Hi @AlessandroN ,
Hi, I changed the folder name removing the space and now it works!
Thank you very much @ashaban!
