Websocket connection to GetProperties outside of mashup
btrevaskis
6-Contributor
We're attempting to bind to the GetProperties websocket from a web application outside of Thingworx in the same way as we would within an mashup via the "update automatically" checkbox. Is this possible?
The JS lib is <Thingworx>/Runtime/tw-javascript-sdk/Common/tw-javascript-sdk/tw-javascript-sdk-0.2.0.js
But I don't think it is designed to be used outside a mashup and this is not a public SDK.
4 REPLIES 4
It can be tricky, the AlwaysOn Javascript SDK used by the GetProperties is not documented nor supported.
btrevaskis
6-Contributor
(To:smainente)
Do you have any information on it? A bit of sample code or anything?
btrevaskis
6-Contributor
(To:smainente)
Thanks.
