What happend with solution central and a DMZ network configuration
DJ_8712454
Hello guys,
Regarding solution central, I have the following question:
In the scenario on a restricted network implementation DMZ for Azure VMs running Thingworx instances Solution Central can be used to deploy the developments and promote to production? or it is mandatory to have internet access between solution central and the Azure VMs?
Looking forward to hearing from you!
DJ
slangley
(To:DJ_8712454)
Hi @DJ_8712454.
ThingWorx would require access to Solution Central for registering the server and pulling down the project, so yes, internet access is required.
--Sharon
slangley
(To:DJ_8712454)
Hi @DJ_8712454.
--Sharon
