What if i have to bind two Functions output/result to Disable property of a Button
VaibhavShinde
Hi ,
I  have facing issue with Binding Two function's Result to Disable property of a Button. i am able to bind only one result to Disable property, but i have another function with different expression and for this also i need Disable the button.
Vaibhav Shinde
Use EventsRouter Widget.
7 REPLIES 7
A thing service can be created to implement the logic. The result of the thing service can drive the button disable property.
Hi @VaibhavShinde.
If the previous response allowed you to solve your issue, please mark it as the Accepted Solution for the benefit of others on the community.
--Sharon
Can't find EventsRouter widget in 8.5.3 now.  Can use the Experssion function in the mashup (lower right corner) to combine 2 inputs to 1 Boolean output.
Hi @VaibhavShinde.
If one of the previous responses answered your question, please mark the appropriate one as the Accepted Solution for the benefit of others with the same question.
Thank you for your participation in our community!
--Sharon
EventsRouter on 8.5 it's now on the Functions side of the Mashup Builder:
slangley
23-Emerald II
(To:slangley)
Hi @VaibhavShinde.
I one of the previous responses allowed you to find a solution, please mark the appropriate one as the Accepted Solution for the benefit of others with the same issue.
--Sharon
