What is causing 'ReferenceError: "Authenticators" is not defined'?
sclifford
1-Newbie
Version: Thingworx 7.1.1
I want to get the ConfigurationTable of a custom Authenticator via a service of a Thing. I need to retrieve a configuration property.
To demonstrate, I am using the ThingworxMobileAuthorizationAuthenticator. The behaviour is the same as for the custom Authenticator.
Using Postman works fine, but when I try to code it using the Entities tab in the Service script, like so:
I get this error when I test it:
What does this mean?
Thank you,
Shane
2 REPLIES 2
ankigupta
(To:sclifford)
Hi Shane Clifford​,
Attached is the export of Authenticators_ThingworxMobileTokenAuthenticator from my instance 7.2.3 and there is no configuration table for it.
Does your custom Authenticator have a Configuration Table?
Also, could please share more details about your custom Authenticator and how it works with postman.
Ankit Gupta
Hi Ankit Gupta​,
Thanks for your reply. Copy and pasted the wrong Authenticator name
I meant ThingworxMobileAuthorizationAuthenticator, which has a configuration table named AuthenticatorConfiguration.
Here's the Postman request:
POST /Thingworx/Authenticators/ThingworxMobileAuthorizationAuthenticator/Services/GetConfigurationTable HTTP/1.1
Host: localhost:8081
appKey: <my_app_key>
Content-Type: application/json
Accept: application/json
Cache-Control: no-cache
Postman-Token: c4df65fa-f5f6-6cca-380c-dc578c00ab4a
    "tableName": "AuthenticatorConfiguration"
And here's the response:
  "dataShape": {
    "fieldDefinitions": {
      "tokenLifeTime": {
        "name": "tokenLifeTime",
        "description": "Token LifeTime",
        "baseType": "LONG",
        "ordinal": 0,
        "aspects": {}
      "generateTokens": {
        "name": "generateTokens",
        "description": "Return generated tokens",
        "baseType": "BOOLEAN",
        "ordinal": 0,
        "aspects": {}
  "rows": [
      "tokenLifeTime": 2592000,
      "generateTokens": true
Now, trying the following in a Service script:
var params = {
  tableName: "AuthenticatorConfiguration" /* STRING */
// result: INFOTABLE
var result = Authenticators["ThingworxMobileAuthorizationAuthenticator"].GetConfigurationTable(params);
Returns:
Error executing service
ReferenceError: "Authenticators" is not defined. (getConfigTable#6)
Details of our custom authenticator (which works successfully) isn't needed here, as the error received is precisely the same for the Thingworx Authenticator.
The custom authenticator stores a value in its configuration table during authorisation. Once logged into the instance, we need to a service that will read the property from our Authenticators configuration table.
Why does Thingworx Composer provide Authenticators under the Entities tab for coding a Script of a Service, and then throw a ReferenceError saying "Authenticators" is not defined... seems like a bug?
Thank you,
Shane
